Hello Guys,
I want to change the lower case words in shared parameters to upper case. Is there any way to make such a change in .rfa/.rte/.rvt file.
Thanks
Suresh C
Hello Guys,
Thanks
Suresh C
Simple answer is no, you have to create a new shared parameter and load it into every family/project you want to replace to old parameter. You can replace one shared parameter with another, if they are the same parameter type (text, number, distance...).
Cheers,
Jeff S.
