Thread: layer properties no longer show up
    2013-04
    Default layer properties no longer show up
    can anyone explain why whenever i select an object the layer properties no longer show up? or why my delete key do not erase object, i must use the erase comand? or why cant i not double click to edit text anymore?
    thks much
    Joe
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,665
    Default Re: layer properties no longer show up
    set PICKFIRST to 1
    set PICKADD to 1 or 2
    set DBLCLKEDIT to on
    If that doesn't help let us know exactly what product & version you're using.
  1. Longer Layer Drop Down Box
    Last Post: 2014-04-13, 10:52 PM
  2. Panel no longer matches properties for circuit!!!!
    By wonderly2 in forum Revit MEP - General
    Last Post: 2012-02-11, 03:55 PM
  3. Replies: 6
    Last Post: 2007-05-30, 02:02 PM
  4. Properties dialog box no longer displays correctly
    By Globey in forum AutoCAD General
    Last Post: 2006-10-02, 11:11 AM
  5. Replies: 18
    Last Post: 2006-09-08, 04:11 PM
