Results 1 to 10 of 18
Thread: Unclear on syntax for returning from a lisp function created in c#
    2008-02
    Toronto, On
    59
    Default Unclear on syntax for returning from a lisp function created in c#
    So I'm trying to understand the process for creating a Lisp function in c# .net.
    public class LispException : System.Exception
                public LispException(string msg) : base(msg) { }
            public class TooFewArgsException : LispException
                public TooFewArgsException() : base("too few arguments") { }
            public class TooManyArgsException : LispException
                public TooManyArgsException() : base("too many arguments") { }
            public class ArgumentTypeException : LispException
                public ArgumentTypeException(string s, TypedValue tv)
                    : base(string.Format("Bad argument type: {0} {1}", s, tv.TypeCode == (int)LispDataType.Nil ? "nil" : tv.Value)) { }
            [LispFunction("DoubleValue")]
            public object DoubleValue(ResultBuffer argBuffer)
                Editor ed = MgdAcApplication.DocumentManager.MdiActiveDocument.Editor;
                Object Res = new ResultBuffer();
                try
                    if (argBuffer == null)
                        throw new TooFewArgsException();
                    else
                        TypedValue[] argArray = argBuffer.AsArray();
                        int ArrayLen = argArray.Length;
                        if (ArrayLen > 1)
                            throw new TooManyArgsException();
                        else
                            if (argArray[0].TypeCode == (short)LispDataType.Double)
                                Res = ((double)argArray[0].Value) * 2.0;
                            else if (argArray[0].TypeCode == (short)LispDataType.Int16)
                                Res = ((Int16)argArray[0].Value) * 2;
                            else if (argArray[0].TypeCode == (short)LispDataType.Int32)
                                Res = ((Int32)argArray[0].Value) * 2;
                            else
                                throw new ArgumentTypeException("numberp", argArray[0]);
                    return Res;
                }//end try
                catch (LispException ex)
                    ed.WriteMessage("\n; error: {0}\n", ex.Message);
                    return null;
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    ed.WriteMessage("\nAutoCAD error: {0}\n", ex.Message);
                    return null;
                catch (System.Exception ex)
                    ed.WriteMessage("\nSystem error: {0}\n", ex.Message);
                    return null;
    I can netload this without a problem, and it does what it's supposed to do...up to a point...
    Command: (setq Num 12)
    12
    Command: (setq Num (DoubleValue Num))
    24
    Command: (setq Num (DoubleValue 12.34))
    24.68
    Command: (setq Num (abs))
    ; error: too few arguments
    Command: !Num
    24.68
    Command: (setq Num (DoubleValue))
    nil
    Command: !Num
    nil
    Notice that the call to (abs) with no arguments resulted in an error, but (abs) didn't return a value to the setq, so Num kept it's previous value.
    How do I create a Lisp function in c# that will properly catch exceptions, but not return nil to the calling function, just like normal autolisp functions?
    Thanks!
    2009-11
    5,538
    Default Re: Unclear on syntax for returning from a lisp function created in c#
    Couple of things....
    Quote Originally Posted by JaCAD View Post
    Firstly, when copying someone else's code, be sure to credit them, and include a link when possible. I can recognize Gile's LispException Classes anywhere, as he shared them with me when I was first learning to work with LispFunction Methods.
    12
    24
    24.68
    Command: !Num
    24.68
    nil
    Command: !Num
    nil
    Simple, either return false, or a ResultBuffer with a Nil LispDataType... Just be sure to handle any Exception(s), as not every LispFunction Method will do simple Math calculations.
    Computer Specs:
    Dell Precision 3630, Core i9-9900K 5.0GHz, 128GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    2009-11
    5,538
    Consider this adaptation:
    using Autodesk.AutoCAD.DatabaseServices;
    using Autodesk.AutoCAD.Runtime;
    using System;
    [assembly: CommandClass(typeof(AUGI.Sample.LispFunctions.Commands))]
    namespace AUGI.Sample.LispFunctions
        public class Commands
            [LispFunction("2X")]
            public object Double(ResultBuffer resbuf)
                if (resbuf == null)
                    return false;
                TypedValue[] args = resbuf.AsArray();
                if (args.Length != 1)
                    return false;
                TypedValue arg = args[0];
                short type = arg.TypeCode;
                if (type == (short)LispDataType.Double)
                    return ((double)arg.Value) * 2.0;
                if (type == (short)LispDataType.Int16)
                    return ((Int16)arg.Value) * 2;
                if (type == (short)LispDataType.Int32)
                    return ((Int32)arg.Value) * 2;
                return false;
    Computer Specs:
    2007-08
    201
    Hi,
    It returns nil because your error handlers ends with: "return null;".
    To avoid this, you can re-throw the exception after having displayed the error message:
                    MgdAcApplication.ShowAlertDialog(ex.Message);
                    throw;
                    throw;
                    throw;
    PS: BlackBox, your adaptation should always return nil in case an exception is raised (nil stands for false too).
    2009-11
    5,538
    Quote Originally Posted by 'gile' View Post
    It (my code) does always return Nil (false) in place of an Exception... However, unless I've overlooked something, Exception handling is only necessary when you've not accounted for a possible Exception through code logic... As I am using logical tests for each step, this is not necessary, as there are no Exceptions thrown.
    Computer Specs:
    2007-08
    201
    Quote Originally Posted by BlackBox View Post
    I do not think so. An invalid input (as an invalid number or type of argument) have to throw an exception instead of returning a valid LISP value: nil.
    Your code hides the exception and may cause an exception later in the calling function:
    (setq a (2x))
    (princ (itoa a))
    ; error: Bad argument type: fixnump: nil
    2009-11
    5,538
    (setq a (2x))
    (princ (itoa a))
    Gile,
    Respectfully, the error you received is from supplying Nil to the ITOA function, which confirms that my code does properly return Nil.
    _$ (setq a nil)
    nil
    _$ (princ (itoa a))
    ; error: bad argument type: fixnump: nil
    _$
    _$ !a
    nil
    _$ (= nil a (2x))
    T
    _$
    Please identify which line(s) in my code above would return an Exception, and I will gladly correct it.
    Computer Specs:
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Here is my attempt
            public static ResultBuffer twice(ResultBuffer resbuf)
                ResultBuffer rb = new ResultBuffer();
                if (resbuf == null) return null;
                try
                        rb = new ResultBuffer(new TypedValue[] { new TypedValue((int)LispDataType.Nil) });
                        rb = new ResultBuffer(new TypedValue[] { new TypedValue((int)LispDataType.Double, (double)arg.Value * 2) });
                        rb = new ResultBuffer(new TypedValue[] { new TypedValue((int)LispDataType.Double, (Int16)arg.Value * 2) });
                        rb = new ResultBuffer(new TypedValue[] { new TypedValue((int)LispDataType.Double, (Int32)arg.Value * 2) });
                    else if ((type == (short)LispDataType.Text) | (type == (short)LispDataType.Nil) | (type == (short)LispDataType.None))
                        rb = new ResultBuffer(new TypedValue[] { new TypedValue((int)LispDataType.Text, "\nInvalid data type\n") });
                    return rb;
                    rb = new ResultBuffer(new TypedValue[] { new TypedValue((int)LispDataType.Text, "\n" + ex.ErrorStatus.ToString()) });
                    return rb;
    "The whole problem with the world is that fools and fanatics are always
    so certain of themselves, and wiser people so full of doubts."
    Bertrand Russell
    2007-08
    201
    That's exactly what I wanted to show. The user expects the '2x' function to return a number. While coding, he makes a typo: (setq a (2x)) then, uses the 'a' variable elsewhere in the code. An exception should be thrown from this place but not from the place the error in the code is (where the variable was set with an incorrect type).
    Built-in functions throws an exception for invalid inputs, they do not return nil and keep on evaluating.
    Exactly at the same places of JaCAD's code (without the unusefull else statements).
    Here's how I'd write it:
                try
                    if (resbuf == null)
                    if (args.Length > 1)
                    switch (args[0].TypeCode)
                        case (short)LispDataType.Double:
                            return (double)args[0].Value * 2.0;
                        case (short)LispDataType.Int16:
                        case (short)LispDataType.Int32:
                            return Convert.ToInt32(args[0].Value) * 2;
                        default:
                            throw new ArgumentTypeException("numberp", args[0]);
                    throw;
    2009-11
    5,538
    Gile,
    You well know that I both respect and admire you, and the work that you've done for this community. I am struggling to understand (perhaps due to a lack of education / experience on my part), as your argument (to me) seems to be one of preference, and not requirement.
    I agree that OOTB LispFunctions such as (1+) will throw an error instead of returning Nil, and that it is usually best to mimic the built-in functionality... However, I stand by this being discretionary, and not a mandatory requirement.
    If throwing LispExceptions were mandatory, then they would also be hard-coded into the API as is the case with many using directives, etc., and they are not.
    Built-in functions throws an exception for invalid inputs , they do not return nil.
    Poor coding practices on the part of the user is not justification... This again demonstrates that code logic mitigates Error/Exception handling. I never claimed to mimic built-in functionality, and was quite clear about what the code does.
    I would never supply an argument to a function, not even (car (entsel)) without first checking it as being non-Nil before processing a dependent variable.
    (if (setq a (2x))
      ;;<-- do work
      (prompt "\n** You made a mistake ** ")
    Side stepping the question with an ambiguous response, and a dig at the OP, is not an answer.
    In good faith, I added a try / catch block, and attempted myriad invalid combinations of arguments, and not one Exception was raised... Instead the code consistently returned false (Nil) at the appropriate line given the ResultBuffer supplied as intended.
                if (resbuf == null)
                    return false;  //<-- (setq a (2x))
                        return (int)args[0].Value * 2;
                    default:
    Respectfully, your own code also returns false (Nil), in lieu of an Exception when no argument is supplied.
    Computer Specs:
  1. Function "order and resize array" not returning values
    By CADfunk MC in forum VBA/COM Interop
    Last Post: 2015-01-06, 02:06 PM
  2. Common Lisp Object System (CLOS) Syntax
    By peter in forum Bridging the Gap: LISP -> .NET -> LISP
    Last Post: 2014-02-17, 02:20 AM
  3. LISP routine returning bad function error
    By playerdraft in forum AutoLISP
    Last Post: 2011-06-15, 04:38 PM
  4. Returning a SYMBOL using VB.Net Lisp Function
    By bweir in forum Dot Net API
    Last Post: 2007-05-11, 03:56 PM
  5. Is it possible to fill in a gap in an object created with the push/pull function?
    By bkolodzaike in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-03-13, 01:26 PM
