Thread: fatal error when using mirror project command
    2013-04
    Default fatal error when using mirror project command
    I'm trying to mirror a project (file size 150MG) and have ungrouped all detail and model groups. Removed all cad and revit links. Only architecture in the file, no MEP or structure. It chugs for about 4 hours and then has a "serious error" where it allows me to save a recovery file, but when I do, the mirror command has not been completed. I have audited the file prior to opening. Any other things I can try to do to get this file to mirror? Revit 2013
    2011-08
    15
    Default Re: fatal error when using mirror project command
    I had this same problem. I made a copy of the project and slowly started deleting objects and performing mirror project to see what the culprit was. Eventually it came down to stairs drawn by component was causing revit to blow up. Try deleting your stairs and then perform mirror by project to positively identify it as the problem. Then you can cut them out, mirror project, bring them back in and manually mirror them or some type of workflow like this.
  1. 2014: HATCH COMMAND SHOWING FATAL ERROR
    By aijazahmed in forum AutoCAD LT - General
    Last Post: 2013-09-26, 12:18 PM
  2. Fatal error when hatch command is picked
    By Garfield in forum Civil 3D - Civil Design Companion - General
    Last Post: 2012-08-13, 02:43 PM
  3. 2012: ALIGN command results in fatal error
    By Limbatus in forum Revit Architecture - General
    Last Post: 2011-11-16, 06:29 PM
  4. Project Associate Fatal Error
    By kdixon in forum AutoCAD General
    Last Post: 2009-03-23, 02:02 PM
  5. AutoCAD 2007 using Xref command causes a Fatal Error
    By ReachAndre in forum AutoCAD General
    Last Post: 2008-10-06, 05:38 AM
Tags for this Thread
