Does anyone have an imperial jalousie window family from version 6.1? I tried Louver fixed.rfa from Steve Stafford posted Apr. 2003, but it doesn't seen to work when the width is changed. I appreciate any help. Thanks.
Sorry that didn't work...I don't recall why I posted a broken family, I'm sure I can come up with some excuse (lame to be sure) if you give me enough time. This one should work better.Originally Posted by veronica.lamb
Awesome! I don't have much time to work on this project. Thanks for the quick response and it works great.
Aloha
--V
I don't have access to an Imperial Jalousie Window family from version 6.1. However, here are a few tips that may help you troubleshoot the issue you're encountering:
Check the family type: Make sure that the family you're using is the correct type for the task you're trying to accomplish. In this case, you want to use a Jalousie Window family, not a Louver fixed family.
Verify compatibility: Make sure that the version of the Jalousie Window family you're using is compatible with the version of Autodesk Revit you have installed. If you're using a newer version of Revit, you may need to find a newer version of the Jalousie Window family that is compatible with it.
Try a different family: If the Jalousie Window family you're using isn't working correctly, you may want to try a different one. There are many different Jalousie Window families available, so you may be able to find one that works better for you.
Check for updates: If you're still having trouble, you may want to check if there are any updates available for the Jalousie Window family you're using. Sometimes updates can resolve compatibility or performance issues.
- - - Updated - - -
If you're still unable to resolve the issue, you may want to reach out to the author of the Jalousie Window family or a Revit expert for further assistance or check this source of .
If you're still unable to resolve the issue, you may want to reach out to the author of the Jalousie Window family or a Revit expert for further assistance or this source .
- - - Updated - - -
