Results 1 to 1 of 1
Thread: GI22-1L: COGO Points and Survey Data in Autodesk Map® 3D A Powerful Combination!
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default GI22-1L: COGO Points and Survey Data in Autodesk Map® 3D A Powerful Combination!
    Instructor: Lucy Kuhns
    Class Description: Incorporate the true power of 3D spatial analysis by using COGO points and land survey information in your projects. In this hands-on class, you will get a head start on understanding and using the most fundamental building blocks of geospatial data — COGO points. You will learn where they come from, how they are created, and the various ways to import them into Autodesk Map 3D. Then, you will see how to manage and use them effectively, which includes point groups, point styling, and point labeling. You will also learn how to use and present land survey data in your Autodesk Map 3D projects, as well as performing basic survey analysis and data query. This course will benefit GIS professionals, civil engineers, and planners needing to effectively understand and utilize land survey information in their GIS projects, as well as land surveyors seeking an AutoCAD® based solution other than Autodesk® Land Desktop for their CAD needs.
  1. GD34-3L: Fields and Sheet Sets: A Powerful Combination
    By Autodesk University in forum General Design
    Last Post: 2013-04-17, 04:32 AM
  2. GD13-5L: Fields and Sheet Sets: A Powerful Combination
    Last Post: 2013-04-17, 04:19 AM
  3. GD23-1L: Fields and Sheet Sets: A Powerful Combination
    Last Post: 2013-04-10, 02:30 AM
  4. Replies: 0
    Last Post: 2008-10-23, 07:29 PM
  5. Additional Data options for Survey Points
    By IanR in forum Civil 3D Wish List
    Last Post: 2008-05-01, 06:27 PM
