Instructors: Henny van der Pol – Autodesk EMEA and Richard Howard & Ken Sam
Class Description: If you have ever put a point on the wrong layer, assigned a line the wrong linetype, or the wrong color to a polygon, this session is for you. We'll focus on classifying real objects while designing. Learn how to implement Autodesk Map 3D 2005 Classification in your application or workflow and you\'ll improve your design efficiency, reduce errors, improve consistency, and make it easier for others to work with your data.
