Results 1 to 1 of 1
Thread: PD23-1: Direct Manipulation of Laser Scan Point Clouds in AutoCAD® Software
    2012-11
    3,030
    Default PD23-1: Direct Manipulation of Laser Scan Point Clouds in AutoCAD® Software
    Instructors: Dirk Langer - Z+F USA, inc.
    Class Description: The class will introduce the LFM Server plug in and demonstrate its capabilities using examples from a variety of process and manufacturing plant environments. LFM Server enables users to view 3D point clouds at high resolution while serving these points to AutoCAD. This enables AutoCAD users to view high-resolution laser scan data within their familiar environment. They can then apply normal tools such as point measurement and drawing, 3D modeling from AutoCAD-based libraries, and extrusion from 2D plan. This class is designed for users of AutoCAD and AutoCAD-based software working on design projects in the process and manufacturing plants market.
  1. 3d laser scan
    By cliff collins in forum Revit MEP - General
    Last Post: 2011-12-01, 01:59 PM
  2. 2012: Autocad 2012 direct-manipulation of UCS icon
    By crbateman in forum AutoCAD General
    Last Post: 2011-06-07, 04:49 PM
  3. Bringing point clouds into BIM software
    By tmad101185 in forum BIM Management - General
    Last Post: 2011-03-13, 04:00 PM
  4. 2011: Scan par Laser direct dans Revit.. enfin la rénovation !!
    By cnevians@yahoo.fr in forum Revit Architecture - General
    Last Post: 2010-11-22, 09:46 AM
  5. Importing SCAN Data, LASER SCANS
    By poonkadirkb in forum NavisWorks - General
    Last Post: 2009-04-07, 09:19 AM
