Instructors: Felicia Provencal – K-Tek Solutions, LLC
Class Description: This class is an in-depth introduction to Autodesk® Raster Design, formerly known as CAD Overlay® , the raster editing, processing, and conversion software from Autodesk. In this class you will learn the concepts behind raster information and how that information can be used within the AutoCAD® environment. All aspects of working with raster images including the sources of raster data, inserting images, and correlating images will be covered. You will see how to process images using tools to change the resolution, brightness and contrast, and color depth. You will learn how to edit raster images by moving, copying, stretching, and rotating portions of scanned images. You will also learn the basics of converting scanning plans into true AutoCAD vector drawings including converting text using OCR tools.
