Results 1 to 1 of 1
Thread: DV21-1: Autodesk VIZ Lighting: Critical Control
    2012-11
    3,030
    Default DV21-1: Autodesk VIZ Lighting: Critical Control
    Instructor: Ted Boardman
    Class Description: Regardless of how good your model is for visualization, mediocre lighting will always result in uninspired renderings. In this session you will learn lighting control and placement that will not only make your scenes more convincing, but also have the advantage of faster rendering. Lighting is not something you can do in the last hour before you deliver a project. It must be approached systematically for optimal control and efficiency. To get the most from this class, you should know the 3ds Max or Autodesk VIZ interface and be comfortable with fundamental lighting techniques.
  1. 2013: How Do I Control Spot Lights in Fly Mode, Realistic Visual Style, Generic Lighting?
    By jaywill in forum AutoCAD 3D (2007 and above)
    Last Post: 2014-04-03, 02:41 PM
  2. VI41-1: Autodesk® VIZ Lighting: Get a Grip
    By Autodesk University in forum Design Visualization
    Last Post: 2013-04-10, 01:09 AM
  3. VI11-1: Lighten Up! Lighting Options in Autodesk VIZ
    Last Post: 2013-04-08, 07:08 PM
  4. DV21-1: 3D Studio VIZ Lighting and Cameras
    By Autodesk University in forum Visualization
    Last Post: 2012-11-24, 07:38 PM
  5. how to control lighting on/off settings in linked files
    By mark.98140 in forum Revit - Rendering
    Last Post: 2008-11-05, 07:51 AM
