Results 1 to 1 of 1
Thread: DV22-2: Autodesk VIZ Materials: Frosting on the Cake
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default DV22-2: Autodesk VIZ Materials: Frosting on the Cake
    Instructor: Ted Boardman
    Class Description: Good materials, along with lighting, are important elements in creating convincing visualizations for your clients. In this session, you will learn to use the parametric maps available in 3ds Max and Autodesk VIZ to make materials that can quickly be changed for increased production value. Use these maps and techniques to generate materials that simulate beveled siding or clapboards, architectural glazing, and acoustic ceiling tiles, for example. Once you learn the controls available with parametric maps, you'll easily discover uses that fit your own needs. Attendees must know the 3ds Max or VIZ interface and have a good fundamental knowledge of the Material Editor.
  1. 2011: Slice the Cake
    By driggins in forum AutoCAD General
    Last Post: 2014-08-26, 08:37 PM
  2. DV22-1L: Creative Modeling Techniques in 3ds Max® and Autodesk® VIZ
    By Autodesk University in forum Design Visualization
    Last Post: 2013-04-17, 04:49 AM
  3. MA35-2: Autodesk Inventor Bill of Materials and Autodesk Productstream
    By Autodesk University in forum Manufacturing
    Last Post: 2013-04-17, 04:36 AM
  4. Replies: 1
    Last Post: 2005-06-07, 02:53 AM
