Results 1 to 1 of 1
Thread: GD31-3: Sheets Happen!
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default GD31-3: Sheets Happen!
    Instructor: Heidi Hewett
    Class Description: Whether you design manufactured parts, maps, or buildings, sheets happen! Learn how to efficiently create, manage, and share your entire set of sheets from one convenient location using the Sheet Set Manager in AutoCAD 2006. At first glance, the powerful functionality offered by the new Sheet Set Manager may seem overwhelming, but you don't have to implement all of the functionality simultaneously. You will see how you can create a sheet set from your existing drawing layouts and then continue to use familiar AutoCAD tools as you implement sheet set functionality one step at a time.
  1. GD41-2: Sheets Happen!
    By Autodesk University in forum General Design
    Last Post: 2013-04-17, 04:46 AM
  2. GD21-1L: Ten Steps to Make Sheets Happen!
    Last Post: 2013-04-17, 04:22 AM
  3. GD33-2: Sheets Happen!
    Last Post: 2013-04-10, 02:26 AM
  4. GD41-1L: Ten Steps to Make Sheets Happen
    Last Post: 2013-04-10, 02:25 AM
  5. GD11-4L: Ten Steps to Make Sheets Happen
    Last Post: 2013-04-10, 02:17 AM
