Results 1 to 1 of 1
Thread: SE32-2: From Physical Model to Construction Drawings with Autodesk® Revit® Structure
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default SE32-2: From Physical Model to Construction Drawings with Autodesk® Revit® Structure
    Instructor: David Sammons - Inlet Technology
    Class Description: Can you use Revit Structure to prepare construction drawings? You bet you can! Revit Structure is not only a powerful physical and analytical modeling tool but it is also a very effective tool for design documentation With Revit Structure, you can prepare construction drawings for printing and delivery to clients, contractors and other team members involved in the building design and construction process In this session, you will learn how to use the Revit Structure design documentation tools to prepare a complete set of well coordinated construction drawings from the physical model Special attention will be given to structural sections and details commonly encountered in structural engineering practice
  1. SE304-3L: Yes! You Can Document Your Autodesk Revit Structure Model
    By Autodesk University in forum Structural Design and Engineering
    Last Post: 2014-12-01, 03:47 AM
  2. SE114-2: Utilizing Autodesk Revit Structure to Model and Document Concrete Reinforcing
    Last Post: 2014-12-01, 03:41 AM
  3. SE32-1L: A Quick Spin on Autodesk® Revit® Structure
    Last Post: 2013-04-17, 04:42 AM
  4. Revit Structure Analytical/Physical model relationship
    By hhall in forum Revit Structure - General
    Last Post: 2009-11-18, 06:08 AM
  5. Construction drawings in Revit
    By Nic M. in forum Revit - In Practice
    Last Post: 2005-02-14, 06:46 PM
