Results 1 to 1 of 1
Thread: SE32-1L: A Quick Spin on Autodesk® Revit® Structure
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default SE32-1L: A Quick Spin on Autodesk® Revit® Structure
    Instructors: Thomas Weir - Brandow & Johnston Associates and Brian Tuffin (Assistant); John Brunt (Assistant)
    Class Description: This session is designed to provide a high-level overview of the structural modeling and documentation process using Autodesk Revit Structure If you are considering Revit Structure, or want to know how to get started with the product, this session will help you see the complete process
  1. SE122-2L: A Quick Spin on Autodesk Revit Structure
    By Autodesk University in forum Structural Design and Engineering
    Last Post: 2014-12-01, 03:48 AM
  2. SE110-1L: A Quick Spin on Revit Structure
    By Autodesk University in forum Structural Engineering and Design
    Last Post: 2013-05-05, 02:19 AM
  3. Replies: 0
    Last Post: 2013-04-17, 04:38 AM
  4. SD14-1L: A Quick Spin on Autodesk Revit Structure
    Last Post: 2013-04-17, 04:20 AM
  5. AR33-5L: A Quick Spin in Autodesk Revit 4.5
    By Autodesk University in forum Building Design
    Last Post: 2013-03-30, 02:18 AM
