Results 1 to 1 of 1
Thread: PD11-1: Introduction to AutoCAD® P&ID: The New P&ID Solution from Autodesk
    2012-11
    3,030
    Default PD11-1: Introduction to AutoCAD® P&ID: The New P&ID Solution from Autodesk
    Instructors: Ursula Sadiq - Autodesk, Inc.
    Class Description: Learn how to use Autodesk Plant to draw intelligent Piping and Instrumentation Diagrams (P&IDs) At the end of the session, you will understand how Autodesk Plant leverages standard AutoCAD productivity tools with user-customizable symbols to quickly and easily create and edit drawings in a way not possible using base AutoCAD You will receive in-depth step-by-step instructions on how to take a typical P&ID and leverage standard AutoCAD functionality to make a number of graphical revisions to the drawing while ensuring all end-line and in-line equipment maintain connectivity and inheritance You will learn how to build a library of commonly used process assemblies and how to ensure consistency of process pipe line properties across multiple drawing files Finally, you will see a significantly modified drawing and learn how to generate project reports for Line, Valve, Instrument, and Equipment
  1. Replies: 0
    Last Post: 2015-08-07, 05:36 PM
  2. Replies: 0
    Last Post: 2013-05-05, 02:39 AM
  3. Replies: 0
    Last Post: 2013-05-05, 02:38 AM
  4. Replies: 0
    Last Post: 2010-07-01, 01:14 PM
  5. No mentioning of Revit in Autodesk family of solution ?!!
    By Richard McCarthy in forum Revit Architecture - General
    Last Post: 2003-10-08, 02:07 PM
