Results 1 to 1 of 1
Thread: CM33-1L: AutoLISP® for CAD Managers
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default CM33-1L: AutoLISP® for CAD Managers
    Instructors: Robert Green - Robert Green Consulting and Phil Kreiker (Assistant); John Herrman (Assistant)
    Class Description: AutoLISP/Visual LISP is a powerful way to extend AutoCAD's functionality, but many avoid using it because they think it's too hard to learn. This course lays out the basics of AutoLISP using a building block approach with practical examples you can use every day to tailor AutoCAD to your specific needs. We'll cover using ACADDOS.LSP to control system startup, how to load files from a network location, some basic syntax, accessing the command line, creating your own user command functions and undefining/redefining commands -- all in a hands-on lab environment. This class assumes you have intermediate AutoCAD capability and the ability to edit/save files using a text editor such as Notepad. No prior AutoLISP experience is necessary.
  1. CM224-1V: AutoLISP® Cheat Sheet for CAD Managers
    By Autodesk University in forum CAD Management and IT
    Last Post: 2015-08-07, 04:06 PM
  2. CM305-1L: AutoLISP for CAD Managers
    Last Post: 2013-05-05, 03:17 AM
  3. CM33-2L: Advanced AutoLISP® Tricks for CAD Managers
    Last Post: 2013-04-10, 01:06 AM
  4. CM22-1L: Advanced AutoLISP® Tricks for CAD Managers
    Last Post: 2013-04-10, 01:04 AM
  5. CM42-1: AutoLISP® Tricks for CAD Managers
    Last Post: 2013-04-08, 07:36 PM
