Results 1 to 7 of 7
Thread: Image room sign and cad model person quality during animation
    2013-04
    5
    Default Image room sign and cad model person quality during animation
    Hi, Producing animation using PNG and presenter, 20 FPS, high render quality.
    The image quality of the frames is good except for room signs and also 3D people, doris is the affected person in the attachment.
    Any advice welcome on how to overcome these defects, this occurs on any frames that include 3d people or room signs.
    For reference, the factory model including room signs and 3D person created in Inventor 2013.
    Navisworks 2013 Simulate.Fujitsu Celsius, 64 bit, windows 7,processor Intel xenon 2.80 GHz, 16 GB useable, Graphics card NVIDIA quadro 4800 with 1.5GB memory.
    Thanks
    Phil
    All AUGI, all the time pauljordan's Avatar
    Rock -- Me -- Hard Place
    749
    Default Re: Image room sign and cad model person quality during animation
    If I had to make a guess without seeing the actual model, I'd say your text for the room signs is directly on the wall and some of it is just barely off the wall allowing it to display.
    As for Doris, it could possibly be the same thing with the different part of her outfit.
    It's like when two pipes occupy the same space in a model, you'll get one striped pipe when you select one of the pipes. The non-selected pipe will still be striped in its original color..
    But, that's a guess, and it's only a guess. If this had been a real solution, I would have told you what to do exactly and how to correct the problems. But, this is only a guess.
    Let us know how things go with it.
    Give a man AutoCad, and he'll draw you a floor plan.
    Give a man Revit and he'll build you a house.
    Give Cadmama a couple of drinks and she'll have everyone singing Rockytop!
    2015-12
    2,095
    I think you're right about the sign. As for Doris, I think thats another example of a known problem with rendering where some faces drop out when the boundaries of the entire scene are extreme. If there were more curved objects (thats where I see it most) it would be more prevalent. If the OP removes everything outside the room and does a still render, I think Doris might end up a little better. If it is that problem, I've read its on the to-do list but haven't heard anything about it more recently.
    749
    I think I'd just use the NW people in there but, then again, they'd move around as you moved.. Hmm.. If you could somehow capture one of them and leave them in a spot, that would work..
    2015-12
    2,095
    Aren't the avatars NWD files under the install folder?
    749
    Quote Originally Posted by dgorsman View Post
    They sure are.. umm, I was just umm.. checking to see if you were paying attention..
    2013-04
    5
    Thank you all for your comments, great help.
    I decided to remove room signs and 3D cad persons from the assembly. I used RPCs in place of 3D cad persons.
    Please see image below.
  1. 2013 Improve animation export quality
    By p.michell374679 in forum NavisWorks - General
    Last Post: 2013-06-21, 02:23 PM
  2. raster image quality
    By nchome in forum Raster Design - General
    Last Post: 2009-02-12, 05:57 PM
  3. Room Parameter - Area per person
    By rdaniel in forum Revit - Platform
    Last Post: 2008-04-08, 08:35 PM
  4. Better Quality Tif Image
    By Griff in forum Revit Architecture - General
    Last Post: 2004-08-17, 08:00 PM
  5. Image Quality
    By JTF in forum Revit - Rendering
    Last Post: 2003-05-10, 10:41 PM
