Results 1 to 10 of 13
Thread: Dimensioning with the Ribbon
    2010-06
    Vancouver, WA
    45
    Default Dimensioning with the Ribbon
    AC Mech 2012
    My current job is the first opportunity I have had to start using the Ribbon. When I use the Ribbon I can not get our "standard" dim styles setting to work.
    I have gone into Dim Style Manager and set to our dim style, but it does not dim the same. I, like most others here revert to classic work space.
    The default of AM-ANSI resets.
    Is it a setting within the ribbon or is it an AM thing. What are my options to get this to work?
    Thanks in advance
    Please don't hold back on the obvious. I might not have though of it. I am willing to go step by step until I figure this out.
    Cairo - no, not Illinois
    4,753
    Default Re: Dimensioning with the Ribbon
    Probably an AM thing. Look into Power Dimensions (or AMPowerDims? I think that's what they are called?) not the same thing as Autocad vanilla dimstyles, and that's probably what the Ribbon calls in Mechanical.
    2010-06
    Vancouver, WA
    45
    Thanks cadtag. I'll give that a try. I think I have tried that before, but I'm willing to try again.
    2010-06
    Vancouver, WA
    45
    I think I have it all figured out, kind of. When I dim it's not right. When I check the properties it shows dim style as "standard$0". In properties I can change it to standard and all is fine.
    What is the "$0"?
    Thanks all.
    100 Club StDoodle's Avatar
    2015-10
    158
    "Under the hood," so to speak, AutoCAD saves sub-styles for Linear, Leader, Radial, Diameter and a couple of others as the base style follow by the dollar sign followed by a number. So if your base style is "standard" then the style "standard$0" is the sub-style for lineal dimensions.
    2012-02-24: Finally got around to installing my home copy of AutoCAD... no longer relying on my horrible memory for "how-to" advice!
    2010-06
    Vancouver, WA
    45
    I still can't get this thing to work properly. I have changed the name of the plot style so it doesn't get confused with the "standard" style. Is there a way to turn off the "power dim" or not make it the default? Most of my drawings have just 5 or 6 dims. I don't need all the extra features that come with power dim.
    4,753
    Rule 2 says that the name 'Standard' should never be used for user content, and left at strictly OOTB settings. Create a new named style for your own stuff, some like companyinitials-Normal
    2010-06
    Vancouver, WA
    45
    That is what I did. The dept. I work for has the dim style as "standard". A couple of us have changed the name.
    2010-06
    Vancouver, WA
    45
    What is rule 1?
    2009-11
    5,520
    Quote Originally Posted by jpglisson View Post
    What is rule 1?
    Rule 1... You do not talk about FIGHT CLUB.
    Computer Specs:
    Dell Precision 3620, Core i7-7700K 4.2GHz, 64GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
  1. Replies: 20
    Last Post: 2015-05-16, 12:14 AM
  2. Replies: 0
    Last Post: 2014-12-01, 03:30 AM
  3. Dual dimensioning with tolerance Dimensioning with punctuation
    Last Post: 2014-10-22, 04:47 PM
  4. dimensioning
    By speedfreak5150 in forum Revit Architecture - General
    Last Post: 2009-05-31, 02:03 PM
  5. Dimensioning?
    By m_r_meza in forum Revit Architecture - General
    Last Post: 2008-06-26, 05:31 PM
