Thread: Graphic Card Requirements - Misleading
    2008-10
    Auckland, New Zealand
    115
    Default Graphic Card Requirements - Misleading
    System Requirements from Autodesk Support:
    OperatingSystems:
    •Microsoft®Windows 7 Enterprise (32-bit and 64-bit)
    •Microsoft® Windows 7 Ultimate (32-bit and 64-bit)
    •Microsoft® Windows 7 Professional (32-bit and 64-bit)
    •Microsoft® Windows 8 (32-bit and 64-bit)
    •Microsoft® Windows XP (32-bit)
    2.0 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
    4 GB or more RAM
    1280x1024 with True Color
    OpenGL 3.3 capable graphics device with 256 MB graphics memory
    and recommended environment is,
    OperatingSystems:
    •Microsoft®Windows 7 Enterprise (64-bit)
    •Microsoft® Windows 7 Ultimate (64-bit)
    •Microsoft® Windows 7 Professional (64-bit)
    •Microsoft® Windows 8 (64-bit)
    2.0 gigahertz (GHz) or faster 64-bit (x64) processor
    8 GB or more RAM
    1600x1050 or higher True color
    OpenGL 3.3 capable workstation class graphics card with 1 GB or greatergraphics memory
    To installand use Autodesk Recap, at least minimum condition should be satisfied.
    Bestregards,
    <name removed>
    Autodesk Support Team
    From Autodesk Product Design Suite 2014 (http://images.autodesk.com/adsk/file...ite_2014.pdf):
    Recommended Graphics Hardware
    BASELINE RECOMMENDATION
    Minimum
    Microsoft® Direct3D 9® capable graphics card or higher (256 MB) or equivalent
    EXCEPTIONS
    OpenGL-capable card (Nvidia or ATI) is required for 3D conceptual
    design using Autodesk® Mudbox®.
    OpenGL 2.0 or higher is required for Autodesk® Alias®
    OpenGL 3.0 or higher is required for Autodesk® ReCap®
    Recommended
    Microsoft® Direct3D 10® capable graphics card or higher (512MB) or equivalent
    If you are wanting to use ReCap you might want to verify what Opengl version your card can support. We have found ReCap did not work with a Opengl 3.2 graphics card.
    Cairo - no, not Illinois
    5,061
    Default Re: Graphic Card Requirements - Misleading
    Which 3.2 card, from which vendor did not work with ReCap? I'm looking at replacing a box in the near future, and am not getting solid info on cards known to run with recap from Adesk. Since it's personal mioney, I do NOT want to try a GTX, and then try AMD, and then buy yet another
    2008-10
    115
    You should be able to look up the spec's on the cards your looking at and verify the Opengl version that the card supports.
    From a quick look at the ATI site, the 6000 series cards and above all support Opengl 4.1, the 5700 series cards support Opengl 3.2.
    I would assume that any card in the last 2 years should be able to support it.
    5,061
    assuming always get's me in trouble....
    2008-10
    115
    Hehe yup.
    u
    me
    BUT if you buying a new one it's a safe assumsion / use google / manufactures site for spec's.
  1. The best graphic card ever!
    By KrakowiAneczka in forum AutoCAD Map 3D - General
    Last Post: 2011-10-28, 08:17 AM
  2. Should I get a new Graphic Card or not?
    By johk in forum Revit - Hardware & Operating Systems
    Last Post: 2008-03-07, 08:50 PM
  3. Graphic card for AGP
    By jpfsiglo in forum Hardware
    Last Post: 2005-08-21, 10:03 AM
  4. Video Card Requirements
    By jrichardson in forum Revit Structure - General
    Last Post: 2005-08-03, 02:40 PM
  5. ADT Graphic card
    By jpfsiglo in forum ACA General
    Last Post: 2005-04-02, 05:02 PM
