Results 1 to 8 of 8
Thread: Coordinate labels
    2003-12
    9
    Unhappy Coordinate labels
    I have a problem regarding our road cross section drawings. Everytime we plot a cross section, we will have to label each point using the ID command and then copying the exact coordinates (elevation and distance from the road centerline). this would be very time consuming and confusing. does anyone had a LISP routine that automatically label a point in a drawing with the current UCS as basis of the coordinate?
    Member Virago87's Avatar
    2005-02
    Toronto, Canada
    29
    Default Re: Coordinate labels
    got this from cadalyst years ago....may get you closer to what your looking for...
    good luck
    2003-12
    9
    Thumbs up Re: Coordinate labels
    thompson21
    thanks for the file that you sent. i still have one problem though. I have a japanese employer who always asks the length of the arc of the pier on its plan view. Usually, i used lines instead of polylines so i can get the exact arc length. is there a way to make a dimension for arc length?
    i hope you can help me again with this matter.
    thanks a lot
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Quote Originally Posted by neilo
    check the code in "circumferebtial dimension" earlier in this forum
    : ) Happy Computing !
    2003-12
    9
    Unhappy Re: Coordinate labels
    sir, i had tried the circumferential dimensioning but it only applies to circle and not for the arcs. can you please tell me how to convert that LISP for arcs length?
    truly,
    Nhel
    13,657
    Hi
    Have a browse of the following thread -
    Dimension an Arc
    Have a good one, Mike
    2002-05
    1,707
    Ok try this :
    (defun c:ArcDim ( / Ent EntDxf ArcLen AngRad Radie AngGo AngEnd )
      (if (setq Ent (entsel ) )
        (progn
          (setq EntDxf (entget (car Ent )) )
          (if (= "ARC" (cdr (assoc '0 EntDxf )) )
            (progn
              (setq Radie  (cdr (assoc '40 EntDxf )) )
              (setq AngGo  (cdr (assoc '50 EntDxf )) )
              (setq AngEnd (cdr (assoc '51 EntDxf )) )
              (if (< AngGo AngEnd )
                (setq AngRad (- AngEnd AngGo ) )
                (setq AngRad (+ (* 2 pi ) (- AngEnd AngGo )) )
              (setq ArcLen (* Radie AngRad ) )
              (setq ArcLen (rtos ArcLen (getvar "LUNITS") (getvar "DIMDEC") ))
              (command "_dim" "angular" Ent "Text" ArcLen pause "" "exit" )
            (princ "Object is not an arc !" )
        (princ "Miss, aim better !" )
      (princ)
    kennet
    2003-12
    9
    thank you very much guys!
    you are indeed of great help.....
  1. 2014: Civil 3D Coordinate
    By wiegmanroger433258 in forum AutoCAD Civil 3D - General
    Last Post: 2014-05-05, 01:43 PM
  2. 2013: 3D Cartesian Coordinate System: Batch input with Work Point Labels
    By rusa67 in forum Inventor - General
    Last Post: 2013-02-04, 04:44 PM
  3. Add certain value to coordinate
    By matti.239210 in forum AutoLISP
    Last Post: 2011-12-29, 06:02 AM
  4. Z Coordinate
    By craigs48.191064 in forum AutoCAD General
    Last Post: 2008-11-28, 05:57 PM
  5. Put X,,Y & Z Labels on the Coordinate Axis Indicator
    Last Post: 2006-05-12, 01:39 PM
