Thread: Using a field to track the Scale of a viewport,,,Viewport from Object?
    2012-02
    82
    Default Using a field to track the Scale of a viewport,,,Viewport from Object?
    I want to link a Field to a Viewport to track the Viewport Scale. However, the Viewport was created from an Object. When I try to select the Viewport I get a list of the items (Polyline and Viewport). I try to select the Viewport option and get,,, nothing.
    Is this possible or not?
    If I have to I can always create a Viewport all by itself but since I have the Object I would like to use it. Call it a challenge. Besides a Viewport is a Viewport regardless of it's origins.
    Thank you
    5,719
    Default Re: Using a field to track the Scale of a viewport,,,Viewport from Object?
    In the Field dialog, change Field Category to Objects, Field Names to Object, Object Type use the Select button to select your Viewport, the select the desired property.
    Standard Viewport, or Viewport from Object does not matter.
    2012-02
    82
    BINGO! Thanks a lot
    5,719
    Quote Originally Posted by boyerd492098 View Post
    BINGO! Thanks a lot
    No worries; I'm happy to help.
  1. Replies: 2
    Last Post: 2017-08-09, 01:04 PM
  2. Field for Dynamic Viewport Scale
    By BThiele in forum AutoCAD Fields
    Last Post: 2014-02-04, 02:14 PM
  3. Object / Viewport Scale field in a block?
    By Cavediver in forum AutoCAD Fields
    Last Post: 2012-09-04, 03:22 PM
  4. Viewport Scale Field
    By drafting1 in forum AutoCAD Fields
    Last Post: 2006-12-29, 02:09 PM
  5. Field, Object, Viewport, Standard Scale
    By rkmcswain in forum AutoCAD Fields
    Last Post: 2006-04-17, 07:31 PM
