Thread: object to field relation
    2004-06
    Slidell, Louisiana
    864
    Default object to field relation
    I have several closed polylines with fields associated with them displaying the area of the polyline.
    How can i determine which field is associated with which polyline? Will it highlight the object? or is it trial and error.
    Robert
    2015-09
    154
    Default Re: object to field relation
    courtesy of mr Lee Mac...
    select the field and it will highlight the referenced object.
    ;;------------------=={ Get Field Objects }==-----------------;;
    ;;  Returns a list of entities referenced by a supplied field ;;
    ;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
    ;;  Arguments:                                                ;;
    ;;  en - Entity containing field (Text / MText / Attribute)   ;;
    ;;  Returns:  List of entities referenced by Field, else nil  ;;
    (defun LM:GetFieldObjects ( en / _getfieldobjects )
        (defun _getfieldobjects ( a )
            (apply 'append
                (mapcar
                    (function
                        (lambda ( a )
                            (if (= 360 (car a))
                                (_getfieldobjects (cdr a))
                                (if (= 331 (car a)) (list (cdr a)))
                    (entget a)
        (if
            (and
                (wcmatch (cdr (assoc 0 (setq en (entget en)))) "TEXT,MTEXT,ATTRIB")
                (setq en (cdr (assoc 360 en)))
                (setq en (dictsearch en "ACAD_FIELD"))
                (setq en (dictsearch (cdr (assoc -1 en)) "TEXT"))
            (_getfieldobjects en)
    (defun c:STF ( / en lst )
        (while
            (progn (setvar 'ERRNO 0) (setq en (car (nentsel "\nSelect Field: ")))
                (cond
                    (   (= 7 (getvar 'ERRNO))
                        (princ "\nMissed, try again.")
                    (   (eq 'ENAME (type en))
                        (if (setq lst (LM:GetFieldObjects en))
                          (foreach ent lst (command "zoom" "o" ent "" ) (redraw ent 3))
                            (princ "\nObject is not a Field, or Field doesn't reference any Objects.")
    2004-06
    Slidell, Louisiana
    864
    Thanks feargt and kudos to Mr. Lee Mac.....great lisp routine. works great. just what i was looking for.
    Robert
    Member vmichl's Avatar
    2002-04
    C.Budejovice, Czechia
    34
    Or you can try the free utility FieldLink - it draws temporary (or permanent) links/arrows between the pairs field-source object (works also on blovks and tables with fields).
    See:
    http://www.cadforum.cz/cadforum_en/f...bjects-tip6795
    Vladimir Michl, www.cadstudio.cz
  1. 2013: Object Position in Field
    By kairichardson539909 in forum AutoCAD for Mac General
    Last Post: 2014-02-10, 09:26 PM
  2. object field values scales with VP?
    By randyspear in forum Dynamic Blocks - Technical
    Last Post: 2010-03-17, 03:26 PM
  3. select object then have area in field
    By ignjat123 in forum AutoCAD Fields
    Last Post: 2009-12-17, 08:09 AM
  4. Formula using an Object's Area Field
    By rklee in forum AutoCAD Fields
    Last Post: 2008-01-17, 05:44 PM
  5. Which object belong to this field? *
    By fk.50940 in forum AutoCAD Wish List
    Last Post: 2005-05-28, 10:53 AM
