Results 1 to 1 of 1
Thread: SE314-1: The Consulting Engineer's Guide to Implementing Revit Structure
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default SE314-1: The Consulting Engineer's Guide to Implementing Revit Structure
    Instructor: James Lupton
    Class Description: This session will provide advice on the implementation of Revit Structure in a structural design office. Learn the key areas for achieving maximum productivity gains and improved presentation standards. Examples of coordination with architects and other design-team members will be given as well as details on how to export data from the model to structural steel fabricators and other manufacturers.
  1. SE314-1: Using Shared Parameters in Autodesk Revit Structure
    By Autodesk University in forum Structural Design and Engineering
    Last Post: 2014-12-01, 03:41 AM
  2. SE314-2: Streamlined Structural Analysis Using Autodesk Revit Structure and RISA
    Last Post: 2014-12-01, 03:40 AM
  3. SE204-1: Leveraging Autodesk Revit Structure as an Engineer
    Last Post: 2014-12-01, 03:37 AM
