Thread: ME310-1: Revit MEP Worksets and Model Management
    2012-11
    3,030
    Default ME310-1: Revit MEP Worksets and Model Management
    Instructors: Martin Schmid, P.E.
    Class Description: Utilizing Revit MEP requires having a Revit Architecture model into which MEP elements can be placed. Many MEP consultants work both with architects and in a separate “linked” model from the architectural model. This advanced level class explores the process for sharing models, including tips for organizing models for the extended design team. Additionally, we’ll demonstrate methods for using worksets to organize Revit models for multidiscipline collaboration. Planned organization of Revit worksets can help the extended design team control model memory requirements, as well as display model elements. Even if you’re not utilizing linked models, many concepts of this class will apply to the multidiscipline design team.
    2005-10
    Sydney
    Default Re: ME310-1: Revit MEP Worksets and Model Management
    Martin, do you have any further documentation on model management rules/processes particularly when using a central file and the owner of the central model needs to release a portion of the building out for an external contractor to work/reference that area and then return it as an "as installed" / "work as executed" file?
    This relates particularly to the ongoing FM side of building refurbishment. Thanks, ChrisL.
  1. 2014: Will more worksets help a model run better?
    By david_peterson in forum Revit Architecture - General
    Last Post: 2014-07-25, 05:19 PM
  2. ME310-2: Building a 3D Model of a 1.5-Billion-Dollar Water Treatment Facility
    By Autodesk University in forum Mechanical Engineering and Design
    Last Post: 2013-05-05, 02:32 AM
  3. Replies: 0
    Last Post: 2013-04-17, 05:05 AM
  4. Ability to pre-assign company standard worksets to the model categories defined in Revit.
    By autocad.wishlist1734 in forum Revit Structure - Wish List
    Last Post: 2011-10-05, 03:07 PM
  5. File Management - Billions of Worksets & DWGS!!
    By mibzim in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2006-02-02, 09:33 AM
