Results 1 to 1 of 1
Thread: DV304-3: Spline Based Modeling in Autodesk Viz
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default DV304-3: Spline Based Modeling in Autodesk Viz
    Instructor: Charles Prettyman
    Class Description: This session will demonstrate a modeling workflow and best practices for creating efficient models that can still be edited. This class will cover the process of going from an architect's 2D CAD drawing (including methods for incorporating typical design changes) to a 3D model created entirely in Autodesk VIZ, ready for materials and lighting. In the process, we'll see how to use a CAD drawing as a reference, and trace over it. We'll witness the incredible flexibility of splines -- especially once you realize how many options you have in the vertices alone. We’ll look at the spline sub-object level and see all the good things that can come from having more than one spline within a spline object. You aren’t limited to just an extruded object; you can modify an extruded spline in all sorts of ways.
  1. Replies: 0
    Last Post: 2014-12-01, 03:38 AM
  2. DV304-1: Non-Photorealistic Rendering Techniques With Autodesk 3ds Max
    By Autodesk University in forum Design Visualization
    Last Post: 2014-12-01, 03:12 AM
  3. Arc Spline based component
    Last Post: 2013-10-07, 04:14 PM
  4. DV304-1L: Architectural Visualization Using AutoCAD and Autodesk 3ds Max
    Last Post: 2013-05-05, 02:46 AM
  5. DV24-1: Spline-Based Modeling in Autodesk® VIZ
    Last Post: 2013-04-17, 04:51 AM
