Results 1 to 1 of 1
Thread: CM305-1L: AutoLISP for CAD Managers
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default CM305-1L: AutoLISP for CAD Managers
    Instructor: Robert Green
    Class Description: AutoLISP/Visual LISP is a powerful way to extend the AutoCAD functionality, but many avoid using it because they think it's too hard to learn. This class lays out the basics of AutoLISP using a building-block approach with practical examples you can use every day to tailor AutoCAD to your specific needs. We'll cover using ACADDOS.LSP to control system startup, how to load files from a network location, basic syntax, accessing the command line, creating your own user command functions, and undefining/redefining commands -- all in a hands-on lab environment. This class assumes you have intermediate AutoCAD skills and the ability to edit/save files using a text editor such as Notepad. No prior AutoLISP experience is necessary.
  1. CM224-1V: AutoLISP® Cheat Sheet for CAD Managers
    By Autodesk University in forum CAD Management and IT
    Last Post: 2015-08-07, 04:06 PM
  2. CM316-6L: AutoLISP® Cheat Sheet for CAD Managers
    Last Post: 2015-08-07, 04:05 PM
  3. CM228-1: AutoLISP® Cheat Sheet for CAD Managers
  4. CM33-1L: AutoLISP® for CAD Managers
    Last Post: 2013-04-17, 04:50 AM
  5. CM42-1: AutoLISP® Tricks for CAD Managers
    Last Post: 2013-04-08, 07:36 PM
