Results 1 to 1 of 1
Thread: CV114-2: Cut to the Sub-base
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default CV114-2: Cut to the Sub-base
    Instructor: Christina A. Davis
    Class Description: Existing surface? Check. Corridor, proposed surface? Check, check. Volume report? Zero! Quantity takeoffs are a vital part of the estimating process and AutoCAD Civil 3D has the tools you need to get the numbers you want. This class will walk you through the Civil 3D process for calculating earthwork volumes and material takeoffs using surfaces and corridors. We'll dig through the missteps that cause zero volumes and cut right to the sub-base.
  1. 2015: Level head family that shows both Project Base and Survey Base
    By david_peterson in forum Revit Architecture - General
    Last Post: 2015-05-28, 04:11 AM
  2. CV114-5: BIM for Civil
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2014-12-01, 04:40 AM
  3. CV114-3L: Building the Perfect Template
    Last Post: 2014-12-01, 04:36 AM
  4. CV114-3: Go "AWOL": Adept Without Land
    Last Post: 2013-05-05, 03:22 AM
  5. Structural - Grade Beam, Coulmn Base, Base Plate
    By roberthale76111940 in forum Dynamic Blocks - Sharing
    Last Post: 2006-07-25, 01:21 PM
