Results 1 to 1 of 1
Thread: CV214-3P: Subdivision Grading Made Easy: Grading Beyond the Roads
    2012-11
    3,030
    Default CV214-3P: Subdivision Grading Made Easy: Grading Beyond the Roads
    Instructors: Brian J. Hailey, PE
    Class Description: Residential subdivision grading can be a tedious task. Learn how to use the tools in AutoCAD Civil 3D 2008 to make this process faster, better, and less prone to errors. You will also learn to grade a detention pond that doesn't have a flat bottom.
  1. CV318-1: Subdivision Plats Made Easy: The Class
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2014-12-01, 04:55 AM
  2. 2015: Phase Grading in a Subdivision
    By tim_newsome in forum AutoCAD Civil 3D - Grading
    Last Post: 2014-10-28, 06:04 PM
  3. CV25-3: Autodesk® Civil 3D® Grading Made Easy
    Last Post: 2013-04-17, 04:47 AM
  4. CV12-2: Subdivision Layout and Design Made Easy
    Last Post: 2013-04-08, 08:31 PM
  5. Change the Grading Criteria of an Existing Grading
    Last Post: 2009-04-24, 07:22 PM
