LSElite
Ive attached the drawing for you Tharwat
Check this out now .
(defun Edit_att (BlockName Property Value / sel i sn e)
;; -------- Tharwat 06. May. 2013 ------- ;
; BlockName = Name of the Attributed Block ( String ) ;
; AttTag = Tag of the Attribute ( String ) ;
; Property = Property (Width / Height) ( String ) ;
; Value = Value of Width or Height (String ) ;
(if (and (tblsearch "BLOCK" BlockName)
(setq
sel (ssget "_X"
(list '(0 . "INSERT") '(66 . 1) (cons 2 BlockName))
(progn
(repeat (setq i (sslength sel))
(setq sn (ssname sel (setq i (1- i))))
(while
(/= (cdr (assoc 0 (setq e (entget (setq sn (entnext sn))))))
"SEQEND"
(if (eq (cdr (assoc 0 e)) "ATTRIB")
(if (eq (strcase property) (strcase "Width"))
(entmod (subst (cons 41 (read Value)) (assoc 41 e) e))
(entmod (subst (cons 40 (read Value)) (assoc 40 e) e))
(princ)
To try the code for height ...
(edit_att "Fields_A1_H" "Height" "1.5")
And this is width ...
(edit_att "Fields_A1_H" "Width" "0.8")
