I have two problems: the first is that I have a routine in place the command of another routine loaded. I tried with command, but it did not work.
Example (with other already loaded routines)
(COMMAND "MUDARLAYER" "TEST" "DOTO-ARCHITECTURE" "")
The other problem is that I want to load into a routine called several at once, so that when you just give the command of this routine, all others are called.
Someone can help?
