Thread: Lisp Help
    2013-03
    Permian Basin
    76
    Default Lisp Help
    Need to get this code to add 10' and 10% to the final length. Any Ideas?
    (defun c:cd ()
     (setvar "cmdecho" 0)
     (graphscr)
     (setq
      p1 (getpoint "\nPick start point ")
      p2 (getpoint p1 "\nPick next point ")
      d1 (distance p1 p2)
      prdist (strcat "\nDistance: " (rtos d1))
     (princ prdist)
     (setq p3 (getpoint p2 "\nPick next point or RETURN if done "))
     (while p3
      (setq
       d0 (distance p2 p3)
       d1 (+ (distance p2 p3) d1)
       p2 p3
       prdist (strcat "\nDistance: " (rtos d0) ", Cumulative distance: " (rtos d1))
      (princ prdist)
      (setq p3 (getpoint p2 "\nPick Next Point "))
     (setq cumd (strcat "Cumulative distance --> " (rtos d1)))
     (prompt cumd)
    (princ "\nType CD to run Cumulative Distance")
    Tallahassee, FL USA
    3,658
    Default Re: Lisp Help
    To add 10' then add 10% to the final length replace
    with
      (setq d1 (*(+ d1 10) 1.1) cumd (strcat "Cumulative distance --> " (rtos d1)))
    2013-03
    Permian Basin
    76
    Works perfect. You are a life saver.
  1. Replies: 13
    Last Post: 2014-01-20, 06:14 PM
  2. NEED HELP WITH LISP ROUTINE - PURGE linetype lisp
    By ECASAOL350033 in forum AutoLISP
    Last Post: 2013-06-21, 01:13 AM
  3. Replies: 3
    Last Post: 2012-05-07, 08:16 PM
  4. Replies: 9
    Last Post: 2012-01-21, 07:58 AM
