Results 1 to 6 of 6
Thread: Can you eliminate a column grand total in a schedule but still grand total another column?
    2011-07
    UK
    45
    Default Can you eliminate a column grand total in a schedule but still grand total another column?
    I had hoped that Revit 2014 would solve this but I cant see how.
    FIRST PROBLEM:
    The Area column calculates its totals from each element: Schedule Properties>Formatting> field 'Area' with Calculate totals ticked
    So this is adding up the total area of each of that type of element, allowing me to calculate the amount from the cost per m2 column
    Then I want to add up all the separate amounts to give a grand total, so have to tick grand totals in Schedule Properties>Sorting/Grouping. That gives me the grand total Amount under column 'Amount' But it also gives me a grand total under column 'Area' which I dont want...how can I get the grand total only in the column I need? If I unclick 'Calculate totals for the area field, I just get a blank field for area..which is not helpful.
    SECOND PROBLEM:
    The grand total for amount insists on left aligning, whereas the fields above are set to right align so monetary values align vertically.
    If the fields above are set to left align, this looks bad when the number of digits in the number are different.
    Has anyone found a solution to these issues?
    It seems so basic I assume I must be missing something obvious, but I havent found any info on this aspect of schedules as yet.
    2015-11
    Madison, WI
    1,318
    Default Re: Can you eliminate a column grand total in a schedule but still grand total another column?
    Under the Formatting tab of the Schedule's properties, select Edit. Then in the 'Fields:' select Area. Now uncheck Calculate totals. Can't help you with the justification of the totals.
    Cheers,
    Jeff S.
    2011-07
    UK
    45
    If I do that then the total of each area is not reported...and so the Area column becomes blank. It would work if I wasnt collecting all the elements of the same type together by not itemising them, but I don't want a huge list of every wall in the project, just a list of the areas for each wall type that I can then cost.
    2011-05
    20
    Quote Originally Posted by robinhill833400 View Post
    FIRST PROBLEM:
    SECOND PROBLEM:
    Did you ever solve this? I am trying to do the same thing and would appreciate any feedback you might have.
    2011-05
    20
    Quote Originally Posted by Seychellian View Post
    ok so i solved it straight after posting this. See below.....
    2015-08
    199
    This is done by setting the Grand Totals under Sorting/Grouping to "Totals Only", then in the Formatting tab make sure that the fields you do not want totaled are set to "No Calculation" and the ones you do want totaled are set to "Calculate Totals". To align the totals in the column click the column letter at the top in the schedule and select the alignment you want. Then you can click in the column header box and align that separately.
  1. 2015: Removing grand total line in schedules
    By jdunkerton689157 in forum ACA General
    Last Post: 2015-01-21, 04:34 PM
  2. 2013: Combining material takeoff schedules / calc grand total for entire project in 1 schedule.
    By bart.oris266980 in forum Revit Architecture - General
    Last Post: 2014-04-28, 08:44 AM
  3. Grand Total text format
    By avalencia60 in forum Revit Architecture - General
    Last Post: 2012-01-06, 07:43 PM
  4. Grand Total in schedules
    By Carlos GT in forum Revit Architecture - General
    Last Post: 2008-12-23, 01:59 PM
  5. Count to grand total ratio in a schedule
    By Archman in forum Revit Architecture - General
    Last Post: 2006-11-17, 09:29 PM
