Thread: Placing a vessel connection pipe flange
    2013-04
    Default Placing a vessel connection pipe flange
    I need to place a pipe flange in an assembly for a process vessel. I placed the pipe stub from the content center, then placed my flange (also from the content center). I then used the Insert Constraint to locate the flange to the end of the pipe stub properly.
    My problem now is that I can not figure a way to constrain the bolt holes in the flange so that they straddle the centerlines of the vessel.
    I should note that I am placing the flange as a part in an assembly file. I am not using the Tube and Pipe tool as this flange is part of the vessel fabrication and I want it to appear on the vessel drawings rather than piping drawings that will be developed later in the project.
    I am a VERY new user of Inventor and the simplest things seem to baffle me. Any advice would be greatly appreciated. This will be a very common application for me going forward so I need to figure this out.
    Thanks very much.
    -Carl
    2015-12
    293
    Default Re: Placing a vessel connection pipe flange
    It sounds possible, but without seeing the assembly, it is hard to say. Can you post it, or if it is proprietary, something similar?
  1. Be able to switch pipe type / pipe system on the fly while keeping connection
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2014-02-18, 03:28 PM
  2. 2013: Pipe Routing - Flange problem
    By ugur.akcay936035 in forum Revit MEP - General
    Last Post: 2013-01-30, 02:20 AM
  3. Pipe Flange Gaskets
    By mvosters in forum AMEP General
    Last Post: 2010-06-09, 07:38 PM
  4. Placing valve in vertical pipe
    By matt__w in forum Revit MEP - General
    Last Post: 2009-08-19, 12:36 AM
  5. Placing insertion point at mid-point of flange on a steel section
    By Spenner in forum Dynamic Blocks - Technical
    Last Post: 2007-06-18, 01:53 PM
Tags for this Thread
