I'm trying to create a Glass Balustrade with 1000mm wide panel modules (900w glass with 50 gap) using the standard glass baluster (made wider).
The problem is when the Main Pattern is set to be 1000mm apart and the corners are set to start 500 in from the end (to get a full panel on the ends) the end panel and the first main panel overlap. There doesn't seem to be a setting that tells the main pattern to be a certain distance from the corner pattern.
I have attached a screen shot of what is happening.
Am I missing something.
Paul
