Results 1 to 6 of 6
Thread: Crashing When Selecting Printer/Plotter
    2011-04
    5
    Angry Crashing When Selecting Printer/Plotter
    When I try to plot a sheet to any of my printers/plotters I get faded white screen and then get kicked out of Autocad completely. Any ideas why???
    HP T1100PS Plotter - HPGL2 driver
    Toshiba eStudio 3540c Printer
    2008-03
    383
    Default Re: Crashing When Selecting Printer/Plotter
    Might be the printer driver, try to uninstall and re-install the latest driver of all your printer.
    2002-01
    3
    Quote Originally Posted by payala380156 View Post
    Check your page setup for the layout/model tab you are trying to plot. If it set to a plotter you don't have or can't access it will freeze and crash AutoCAD.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,686
    If I try to plot an old drawing setup with a plotter we no longer have I get an AutoCAD Warning. It gives the plotter configuration, says it cannot be used for one of these reasons: the driver cannot be found, the device cannot be found, or the driver has a problem. The None plot device has been substituted.
    I don't believe freezing and crashing AutoCAD is an acceptable response to any AutoCAD command and should always generate a crash report worth filling out.
    2001-03
    Tallahassee, FL USA
    3,686
    Does this only happen on the network? Plotting uses file space and I've had similar problems trying to plot a drawing on the network, your MIS is to blame not AutoCAD.
    Hello friend, it is better to re-install your Auto-cad software to solve problem of crashing when selecting a printer or plotter.
  1. Printer/Plotter List Order
    By nealehiggs in forum Hardware
    Last Post: 2012-10-22, 10:11 AM
  2. Printer and Plotter Bugs with Revit 2012
    By Alan aka cadalot in forum Revit Architecture - General
    Last Post: 2012-02-07, 10:27 PM
  3. Plotter / Printer Recommendations for a newbie
    By bt75711 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2007-11-02, 12:55 PM
  4. Publish to different printer/plotter
    By dmorin in forum ACA General
    Last Post: 2007-01-25, 06:19 PM
  5. printer/plotter
    By cgrover in forum Revit - Hardware & Operating Systems
    Last Post: 2004-02-05, 04:33 PM
Tags for this Thread
