We can pull the thermal coefficiant from walls etc and put it in schedules as it appears in the field list.
When trying to create a multi category tag to show U-value, the Heat Transfer Coefficient ( U or R) field doesn't appear in the field list.
So far I can only see a workaround by manually copying it into the description field...not very BIM, and not a good idea if the structure is edited.
Also I want to keep the description clear for use in multi category tags to give instructions to the contractor.
Building control approval seems to go faster if the u-value is shown on the drawing for each wall type etc., they dont really like cross referencing to look up the schedule!
Has anyone found a way to directly access the Heat Transfer Coefficient from a tag?
...Robin
