Results 1 to 10 of 16
Thread: Replace old xref files with a set of new xref files
    2010-05
    9
    Default Replace old xref files with a set of new xref files
    Hi Good Afternoon, evening, morning,
    Firstly i must apologise if i have posted this in the wrong area, i didnt see a specific forum for .lsp related issues
    I am looking for any assistance possible, as from the title i am looking at some kind of Lisp code that will change the X-Ref file name from 'x' to 'y' for multiple x-refs on multiple drawings.
    I have found some information on Google that pointed to a thread back in 2010, instead of copying the code into this thread i have attached the link below
    http://www.cadtutor.net/forum/archiv...p/t-38673.html
    I would like someone to confirm if the LISP code that is metioned in the above thread worked and if someone could please explain how i would go about loading it into my computer and autocad softaware.
    Case history..... Our office in Hamburg has a huge number of x-refs (3000) that have been created and we now wish to update the x-ref file name from a German based accronym to a universal accronym for our global offices. Is there a way that when we open an existing drawing containing x-refs that the Lisp function would rename the x-refs to the new x-ref file name?
    once we have renamed the x-refs we are lookling to relocate them on an international file server for all offices to use, i belive that reference manager can be used for this, its the x-ref file name renaming that has me stumped I would appreciate any assistance where ever possible....
    Many Thanks Kind Regards Simon
    2013-03
    Can you say DERECHO, Iowa
    66
    Default Re: Replace old xref files with a set of new xref files
    Quote Originally Posted by simon_coupland View Post
    If I'm reading your post right, this might just work... (This is a script not a lisp, so you would need ScriptPro 2 or something to run it...)
    -rename
    b
    xrefX_old
    xrefY_new
    -xref
    p
    xrefY_new
    "C:\NEW XREF\xrefY_new.dwg"
    2010-05
    9
    Hiya,
    Firstly .... thank you for your feedback
    This is new to me, i have a copy of ScriptPro that i got off the internet,
    so as a newbe to all this my understanding is that i copy the above text into Notepad and save as a .scr file and then load it into the drawings using ScriptPro....
    if all the above is coorect then i am half way there, my only other question is:
    what is the proceedure for repeating this process if there are multiple X-Refs within a drawing that need to be renamed?
    2009-11
    5,713
    Scripts are very slow by comparison, as they require that each Drawing be opened within the Editor... Methinks you'd be much better off using ObjectDBX to iterate a directory of drawings, to edit the external references programmatically... Just depends on how adept you are at Visual LISP.
    Computer Specs:
    2010-05
    9
    Thank You all for the various options really appreciate as much input as possible
    i did come across this when i googled it, i am really interested int the rename part of the .lsp below
    ("X-TEST-1a" . "X-TEST-1b")
    ("X-TEST-2a" . "X-TEST-2b")
    ("X-TEST-3a" . "X-TEST-3b")
    something like that looks like it would work, this way i could enter a list of 100 - 200 old to new X-Ref file names to one LISP file and get it to autorun everytime AutoCAD starts...
    Please let me know what part of the code below would do, it seems there is more to it than just rename at the moment
    Many Thanks
    Simon
    ; << Replace old xref files with a set of new xref files >>
    ; << Version 1.0 >>
    ; NOTE: If new xrefs are in a different folder, you must call out
    ; XrefPathChange.lsp from the code below.
    (defun c:xrefnamechange (/ b bcol path )
    (vl-load-com)
    (setq bcol (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
    (foreach blk '(
    ;>>>>> Enter all xref names below in this format >>>>>>
    ;>>>>> ("OldXrefName" . "NewXrefName") >>>>>>
    (if
    (and
    (not (vl-catch-all-error-p (setq b (vl-catch-all-apply 'vla-item (list bcol (car blk))))))
    (= (vla-get-isxref b) :vlax-true)
    (progn (vla-put-name b (cdr blk))
    (if (= (setq path (vl-filename-directory (vla-get-path b))) "")
    (vla-put-path b (strcat (cdr blk) ".dwg"))
    (vla-put-path b (strcat path "\\" (cdr blk) ".dwg"))
    (vla-reload b)
    ;>>> XrefPathChange.lsp call out here. >>>>
    ;>>> Enter all xref paths to be changed in this format. >>>>
    ;>>> (xrefpathchange "c:\\Oldfolder\\oldfolder" "c:\\newfolder\\newfolder") >>>>
    ;>>> Note: Remove code if new xref path is unchanged. >>>>
    ;>>> Add ; infront of each line to block code. >>>>
    (xrefpathchange "c:\\AutoCAD Customisation" "c:\\AutoCAD Customisation\\Working")
    (XReload)
    (princ)
    );end of c:XrefNameChange
    ;.... Xref Path Change sub routine by ronjonp ....
    (defun xrefpathchange (path1 path2 / newpath xrpath)
    (vl-load-com)
    (vlax-map-collection
    (function
    (lambda (x)
    (if (= (vla-get-isxref x) :vlax-true)
    (progn (setq xrpath (strcase (vlax-get x 'path) t)
    path1 (strcase path1 t)
    path2 (strcase path2 t)
    (if (and (vl-string-search path1 xrpath)
    (setq newpath (vl-string-subst path2 path1 xrpath))
    (findfile newpath)
    (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-path (list x newpath)))
    (princ (strcat "\n**OLD path found but was not changed!\n" xrpath))
    (princ (strcat "\n" newpath))
    (princ)
    ); end of XrefPathChange
    ;.... Xref Reload sub routine .......
    (defun XReload (/ cObj cName); Updated 2007-10-1: added error trap
    (defun *error*(msg)
    (setvar "modemacro" ".")
    (setvar "cmdecho" 1)
    (princ "\n...Reload xref terminated!!! :( ")
    (princ)
    ); end of *error*
    (setvar "modemacro" "Reloading loaded xrefs......please wait......")
    (setvar "cmdecho" 0)
    (setq cObj(tblnext "BLOCK" T))
    (while cObj
    (setq cName(cdr(assoc 2 cObj)))
    (if
    (and
    (=(logand(cdr(assoc 70 cObj))32)32)
    (=(logand(cdr(assoc 70 cObj))4)4)
    ); end and
    (progn
    (vl-cmdf "_.xref" "_unload" cName)
    (vl-cmdf "_.xref" "_reload" cName)
    ); end progn
    ); wnd if
    (setq cObj(tblnext "BLOCK"))
    ); end while
    (prompt "\n--- Xref change finished! ---")
    (princ)
    ); end of XReload
    2009-11
    5,713
    Please edit your post to include [CODE ] Tags.
    Computer Specs:
    2010-05
    9
    Without sounding like a complete Numpty.... what are [code] tags ???
    the above code was from a post off the internet, i can copy the link into this reply if that helps?
    http://www.cadtutor.net/forum/archive/index.php/t-38673.html
    Sorry for sounding clueless
    Regards
    Simon
    2013-03
    66
    Simon,
    I think that BlackBox is stressing that using Code Tags will eliminate the emoticons from the code you pasted in for example "
    c:xrefnamechange
    " is not equal to "crefnamechange"....
    2013-03
    66
    This image shows what I typed for the previous example...
    2010-05
    9
    Ha Ha..... i only just noticed that it copied in the smiley faces ..... sorry my bad ooooops
    hopefully the link i posted should help clear up any confusion
  1. Replies: 7
    Last Post: 2024-02-17, 01:56 AM
  2. Find which files contain a certain xref
    By geoff.80680 in forum AutoCAD General
    Last Post: 2009-02-09, 06:04 PM
  3. Repath Xref Files
    By harilalmn in forum VBA/COM Interop
    Last Post: 2008-04-16, 02:07 PM
  4. xref Files
    By rhayes.99001 in forum ACA General
    Last Post: 2005-11-18, 05:14 PM
  5. XREF files not Updating
    By CLEMENTEM in forum AutoCAD General
    Last Post: 2005-04-16, 12:14 AM
