Thread: AutoCAD hangs when selecting the Hatch Tool?
    2011-02
    Southampton NY
    7
    Exclamation AutoCAD hangs when selecting the Hatch Tool?
    I have not found this with any other tool. But when I select the Hatch Tool AutoCAD hesitates for about 10 long seconds. Once it's finished it functions fine, but everytime I select, either by selecting the button, choosing from the menu, or right clicking for "last used tool" it hesitates.
    Thanks for any ideas.
    - J
    2013-03
    Can you say DERECHO, Iowa
    66
    Default Re: AutoCAD hangs when selecting the Hatch Tool?
    Quote Originally Posted by Statboy View Post
    - J
    Are you working remotely or perhaps on a different server than you used to be?
    Earth
    9,805
    - J
    It's instantly and constantly trying to find something to hatch when you launch the command. So depending on the complexity of the drawing, it could even appear to lock up AutoCAD (and in same cases, may do it)
    (Try it in a new, empty drawing, it should be pretty fast)
    Personally, I set HPDLGMODE to 1 which makes AutoCAD revert to the old method of displaying the dialog box first.
    R.K. McSwain | CAD Panacea |
    2011-02
    Southampton NY
    7
    No, Same server, The files are located on the server, the program is loaded on the workstation. All files are in one building.
    2011-02
    Southampton NY
    7
    Thanks, rkmcswain, It appears it might be a "particular" file issue. It functions very fast in a "new" file. I will try the HPDLGMODE.
    Thanks for your help.
    - J
  1. Hatch Multiple Areas with Tool Pallette Hatch
    Last Post: 2013-01-16, 04:51 AM
  2. hatch by selecting boundary points
    By ccowgill in forum AutoLISP
    Last Post: 2009-02-27, 12:38 PM
  3. Replies: 2
    Last Post: 2006-08-31, 06:43 AM
  4. Selecting Associative Hatch also selects Hatch Boundary
    By gadjet in forum AutoCAD General
    Last Post: 2006-08-11, 07:14 PM
Tags for this Thread
