Results 1 to 1 of 1
Thread: 109 3dsmax adapter error issues
    2013-05
    2
    Lightbulb 109 3dsmax adapter error issues
    Hi Guys, I have a rendering farm setup. have previously ran alot of files over to the farm to render and all renders fine..
    but now i am having some issues with unknown error,109 adapter error issues and 0x2736 socket error.
    I have already did a restart of system, restart of job and all does not seems to work.
    I have attached below the recent logs on the error.
    Server log
    : 109
    3dsmax adapt�I�,<2
    2013/05/30 05:08:53 ERR 3dsmax adapter error : Autodesk 3dsMax 15.0 reported error: An unexpected exception has occurred in the network renderer and it is terminating.
    3dsmax adapter error : The pipe has been ended.
    : 109
    2013/05/30 05:08:53 INF Application is down
    2013/05/30 05:08:54 INF Adapter returned unexpected code -2 for "C:\Program Files\Autodesk\3ds Max 2013\maxadapter.adp.exe" "-o" "ShutDown" "-l" "Info"
    2013/05/30 05:08:54 ERR Unknown Error
    2013/05/30 10:01:27 ERR Error accepting connection: An operation was attempted on something that is not a socket. (0x2736).
    Manager log
    : 109
    2013/05/30 09:44:28 WRN Server scda_node07-pc flagged as failed for job 'ADD_recover_WITH KITCHEN'
    2013/05/30 09:44:37 WRN Task error from scda_node06-pc
    2013/05/30 09:44:37 ERR Job 'ADD_recover_WITH KITCHEN' (Autodesk 3ds Max 2013 (64-bit)) failed for scda_node06-pc
    2013/05/30 09:44:37 ERR Error message: 3dsmax adapter error : Autodesk 3dsMax 15.0 reported error: An unexpected exception has occurred in the network renderer and it is terminating.
    : 109
    2013/05/30 09:44:37 WRN Server scda_node06-pc flagged as failed for job 'ADD_recover_WITH KITCHEN'
    2013/05/30 09:44:59 INF Server scda_node07-pc out of cool off period.
    2013/05/30 09:45:07 INF Server scda_node06-pc out of cool off period.
    2013/05/30 10:01:26 WRN Server scda_node04-pc going down
  1. 2013: display adapter rongr
    By eng_m_hanafi158046 in forum Revit MEP - General
    Last Post: 2013-01-24, 06:53 PM
  2. un livre à adapter ...
    By cnevians@yahoo.fr in forum Revit Architecture - General
    Last Post: 2012-07-18, 02:19 PM
  3. Màj vers 3dsMax ou 3dsMax Design ??
    By sittingbull86 in forum 3ds Max - General
    Last Post: 2010-10-27, 08:23 AM
  4. adapter ossature imbriqué
    By yusukens82 in forum Revit Architecture - Families
    Last Post: 2008-10-02, 01:12 PM
  5. Revit : HELP ! Adapter la façade au Terrain
    By steph2311 in forum Revit Architecture - General
    Last Post: 2006-06-07, 07:44 AM
