svr_kjg705384
Hello All,
I have some general questions which I can't seem to find and answer on the net.
1. I used ACAD 2009 previously and when I double clicked a line/circle, the Properties Box opened. In A2014, the Quick Properties Box opens. Can I change it NOT to open the Quick Properties and just open the standard Properties Box?
Type CUI, under Double Click Actions, scroll down till you find Circle & Line, expand that and you will see QUICKPROPERTIES, on the right side of the CUI change the macro from QUICKPROPERTIES to PROPRERTIES, click apply. You should also change the command name so you dont get confused.
2. When double click on a Dimension in A2014, it shows me to edit the text in that dim. A2009 the Properties Box opened. Can I change this so it works like 2009?
Type CUI, under Double Click Actions, scroll down till you find Dimensions, expand that and you will see DTEXT, on the right side of the CUI change the macro from DTEXT to PROPRERTIES, click apply. You should also change the command name so you dont get confused.
3. When I create a dim A2014 and it is NOT centered/aligned, it does NOT show using right-click like A2009 to HOME/center the text.
Hover off the grip where the dimension is located, a you will see a tool tip box open, move the mouse and click on reset text postion
Please ask if more questions are needed. Sorry for being vague on my questions.
Thank you & Best Regards
KenJG - ACAD2014
