Thread: add a line from one block to another block, but I can not use the "Base Point"
    2013-03
    Brasil - São Paulo
    4
    Post add a line from one block to another block, but I can not use the "Base Point"
    Hello!
    I sent an attachment to explain, but in short I need to add a line from one block to another block, but I can not use the "Base Point" as a reference
    I added a "point parameter" and managed to get the X, Y "Point", but I can not find the direction of the "Point Parameter" in relation to "Base Point", then the line out on the wrong side
    The screenshot is attached.
    Already thank!
    2007-07
    104
    Default Re: add a line from one block to another block, but I can not use the "Base Point"
    The screenshot is not attached. I don't understand why you can't use the base point / insertion point. Are you sure? If so you could search for coordinates of elements in the block, but that sounds like overcomplicating things to me (as does your "point parameter" solution).
  1. Replies: 0
    Last Post: 2013-06-05, 04:16 PM
  2. "Point de base du projet" et "Point de relevé"
    By fabrice.bon in forum Revit Architecture - General
    Last Post: 2010-03-30, 10:53 AM
  3. Title Block Line "Auto-connects"
    By Batman in forum Revit Architecture - General
    Last Post: 2008-10-13, 01:08 PM
  4. HOW switch COMMAND "BLOCK" THE "Scale Uniformly"
    By viz_ken1030 in forum AutoLISP
    Last Post: 2006-11-17, 12:41 PM
  5. Linear stretch action, keep base point of the block at midpoint of a line
    By rustific41657 in forum Dynamic Blocks - Technical
    Last Post: 2005-12-16, 04:27 AM
