Results 1 to 7 of 7
Thread: Error: too few arguments in a function
    2013-06
    6
    Question Error: too few arguments in a function
    Hello, I am currently developing a routine that will find the total length of all selected polylines, lines ect, and, if the user would like, estimate how long it will take a machine to cut it. I recently separated the code so that the estimated time was an optional function. But now when I run it Cad, not the build window, tells me I have too few arguments, I've been staring at it all day and surfing the boards for anything that may help but alas I can't figure it out, is there anyone who could point me in the right direction?
    Much Thanks!
    (defun C:justdoit (ssSelections sngLength runType a)
    (setq ssSelections (ssget (list (cons 0 "*POLYLINE,LINE,ARC,CIRCLE,SPILNE")))
         	   sngLength	0
      (initget "Yes No")
      (setq runType (getkword "\n Would you like the Estimated Machining Time to be Calculated? Yes/<No>: "))
      (if (= runType No)
    	(setq a (function <funtype1>))
        	(setq a (function <funtype2>))
      (defun funtype1 (/ intCount entItem sngLength objItem)
          (repeat (setq intCount (sslength ssSelections))
           (setq intCount  (1- intCount)
         		entItem   (ssname ssSelections intCount)
         		objItem   (vlax-ename->vla-object entItem)
         		sngLength (+ snglength (vlax-curve-getDistAtParam objItem
         				   (vlax-curve-getEndParam objItem)
         				  );vlax
    			     );+sngLength
           );setq
          );loop
          sngLength
       );function
    (defun C:GetLength (/ intCount entItem sngLength objItem impSpeed nubTools
    		    passDepth materialThickness passNub machTime)
      			(setq 	impSpeed	(getreal "\nWhat is the feedrate (IMP value) of your machine? ")
    				nubTools	(getreal "\nHow many cutting heads will be used?")
    				passDepth	(getreal "\nWhat is the pass depth (inches value)?")
    				materialThickness(getreal "\nWhat is the thickness of the material (inches) ")
           				passNub		(/ materialThickness passDepth)
           				machTime	(* (/ sngLength impSpeed) passNub(+ 1.5 (* 1.5 nubTools))) ;assuming it takes 1-1/2 minute to change a bit
    	);setq
         				  );vlax1
    			     );+snglength
    			);setq
    	  ); Loop
    sngLength
     machTime
      );function
      );main function
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Default Re: Error: too few arguments in a function
    Quote Originally Posted by lepley.amber388103 View Post
    Much Thanks!
                sngLength    0
      (initget "Yes No")
      (if (= runType No)
                           );vlax
                     );+sngLength
           );setq
          );loop
          sngLength
       );function
        );setq
                           );vlax1
                     );+snglength
                );setq
          ); Loop
    sngLength
     machTime
      );function
      );main function
    1st of all, I am also learning autolisp.
    And 2nd, as I can see that you just start to learn the program.
    The suggestion from my experience is that it would be easier if you grab a simple code and learn from it.
    And before loading the code to autocad, you should check it out by using "VLIDE" in autocad (coomand = "VLIDE").
    On the code you posted, there is paren putting in the wrong location, and function "<funtype2>" is missing.
    You may need to pay more attention to the details.
    HTH.
    2009-11
    5,536
    ... tells me I have too few arguments, I've been staring at it all day and surfing the boards for anything that may help but alas I can't figure it out, is there anyone who could point me in the right direction?
    You're showing all 'arguments' in lieu of 'variables'... Consider this small change:
    (defun C:justdoit (;|arguments|; / ;|variables|; ssSelections sngLength runType a)
    ;;; <snip>
    ... More on the DEFUN function.
    Computer Specs:
    Dell Precision 3620, Core i7-7700K 4.2GHz, 64GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    2013-06
    6
    Thank you for all the help on this, I ironed out the arguments issue and done a bit of tweaking and now it runs everything up until the point in which the length should be returned when vlide tells me: ; error: bad argument type: numberp: nil.
    I'm sure this is a simple fix but my LISP is very rusty.
    any help on this matter would be greatly appreciated
    Thanks
    (defun C:polysum (/ runType a yes no)
    (defun funtype1 (/ intCount entItem objItem sngLength)
    							 objItem
                           				);vlax
                        			);+sngLength
           );setq
          );loop
          (princ (strcat "\nTotal Length "sngLength))
       );function
      (defun funtype2 (/ intCount entItem sngLength objItem impSpeed nubTools
    	);setq
         				  );vlax1
    			     );+snglength
    			);setq
    	  ); Loop
    	       "\nEstimated Machine Time "machTime))
      );function
         	  			 sngLength	0)
      (initget "Yes No")
      (if (= runType "No")
    	(setq a (funtype1))
        	(setq a (funtype2))
    2009-11
    5,536
    The STRCAT function concatenates multiple strings, but you're attempting to concatenate strings and numbers (which is the cause of your bad argument error)... You might find the RTOS function useful.
    Computer Specs:
    2013-06
    6
    well that make sense haha Thanks!
    2009-11
    5,536
    No worries; I'm happy to help.
    Computer Specs:
  1. error: too many arguments??
    By tedg in forum AutoLISP
    Last Post: 2010-08-31, 02:58 AM
  2. error: too many arguments Using IF Function
    By ccruz in forum AutoLISP
    Last Post: 2009-08-06, 09:31 PM
  3. Replies: 12
    Last Post: 2006-12-07, 03:22 PM
  4. Help fix a routine - Error: too few arguments
    By cadd4la in forum AutoLISP
    Last Post: 2006-01-10, 06:06 PM
  5. ; error: no function definition: ACET-ERROR-INIT
    By gab.83408 in forum AutoCAD Customization
    Last Post: 2005-03-01, 12:19 AM
