Results 1 to 7 of 7
Thread: Need help making a triangle lisp and have no idea.
    2013-06
    Default Need help making a triangle lisp and have no idea.
    I need to write an AutoLISP program which asks user to select a point and then draws an equilateral
    triangle by the length 3 from that point. Any ideas?
    All AUGI, all the time Richard McDonald's Avatar
    2002-01
    At right angles to reality
    537
    Default Re: Need help making a triangle lisp and have no idea.
    I am probably missing something but you could use the poly command and set the number of sides to 3.
    Probably worth asking a mod to move this to the lisp area for better answers.
    Regards
    2001-12
    St. Louis
    5,347
    I've moved this post to the lisp forum, thanks.
    I'd also suggest checking out some of the available LISP tutorials in the Autodesk University Course archives... http://forums.augi.com/forumdisplay....nd-Programming
    Melanie Stone
    @MistresDorkness
    ARCHIBUS, FMS/FMInteract and AutoCAD Expert (I use BricsCAD, Revit, & Tririga, too)
    Technical Editor
    All AUGI, all the time Tharwat's Avatar
    2010-06
    922
    Simple code ..
    (defun c:Test (/ p1 p2 p3)
      (if (setq p1 (getpoint "\n Specify the base point :"))
        (progn
          (setq p2 (polar p1 0. 3.)
                p3 (polar p2 (* (/ pi 3.) 2.) 3.)
          (command "_.pline" "_non" p1 "_non" p2 "_non" p3 "c")
      (princ)
    AUGI Addict alanjt's Avatar
    2008-02
    1,141
    Is the POLYGON command not good enough?
    Civil 3D 2017 ~ Windohz 7
    Dropbox
    Turlock, CA
    5,756
    In addition to the comments from others, I had this old lisp laying around. It does a little more than what you're asking.
    C:> ED WORKING....
    2009-11
    5,538
    Quote Originally Posted by Statler View Post
    I am probably missing something but you could use the [polygon] command and set the number of sides to 3.
    Quote Originally Posted by alanjt View Post
    This.
    Quote Originally Posted by Tharwat View Post
    Simple code ..
        (progn
      (princ)
    ... Simpler code :
    (defun c:FOO ()
      (command "._polygon" "3" "edge" pause pause)
      (princ)
    Computer Specs:
    Dell Precision 3630, Core i9-9900K 5.0GHz, 128GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
  1. Wishlist - Got an idea for a new function for LISP?
    By peter in forum Bridging the Gap: LISP -> .NET -> LISP
    Last Post: 2014-01-30, 02:39 PM
  2. file creation lisp idea
    By LSElite in forum AutoLISP
    Last Post: 2013-01-17, 11:20 PM
  3. Idea for Lisp Routine
    By robert.1.hall72202 in forum AutoLISP
    Last Post: 2005-05-04, 03:00 PM
  4. Good idea for lisp routine
    Last Post: 2005-02-14, 03:20 PM
  5. Making a directory from LISP?
    By tyshofner in forum AutoLISP
    Last Post: 2005-02-04, 05:36 AM
