Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: Convert Explode command to Burst command?
    Design Visualization Moderator stusic's Avatar
    2004-10
    Denver, Colorado
    1,515
    Default Convert Explode command to Burst command?
    Hello Everyone!
    Quick question: Is there an easy way to convert
    (foreach obj (vlax-invoke tmp 'explode))
    to
    (foreach obj (vlax-invoke tmp 'burst))
    Or something that effectively does the same? I know I can't use the ET commands right out of the box, but I'm not sure how/if I can use it like the above.
    Thank You,
    -stu
    Phillip Bradshaw
    Lead Pixel Pusher, Lucid Design Studio
    CAD Detailer, Proctor Productions
    A doctor can bury his mistakes but an architect can only advise his clients to plant vines. - Frank Lloyd Wright
    2004-10
    Denver, Colorado
    1,515
    Default Re: Convert Explode command to Burst command?
    From what I've seen from others' questions, it seems I can really only feed the burst command a selection set if I modify the burst.lsp. Can anyone verify this is correct before I go wasting away the rest of the day?
    Phillip Bradshaw
    5,538
    Quote Originally Posted by stusic View Post
    If memory serves, BURST is an Express Tool, and you need to supply an implied selection when called from code... Translation, use SSSETFIRST prior to your (command "burst") call.
    5,538
    Quickly written pseudo-code (untested):
    (if (and (setq oldEnt (entlast))
             (setq e oldEnt)
             (setq add (ssadd))
             (vla-explode obj)
      (progn
        (while (setq e (entnext e))
          (if (= "INSERT" (cdr (assoc 0 (entget e))))
            (setq add (ssadd e add))
        (sssetfirst nil add)
        (c:burst)
    2004-10
    Denver, Colorado
    1,515
    I haven't been able to feed BURST a selection set. I think I may have to re-write parts of the original BURST code or approach the problem from another way that just uses EXPLODE...
    Phillip Bradshaw
    AUGI Addict alanjt's Avatar
    2008-02
    1,141
    If you open the burst.lsp, you can strip out the subroutines and do what you want. Don't post them, since it's all copyright material.
    Civil 3D 2017 ~ Windohz 7
    Dropbox
    Tallahassee, FL
    3,400
    It can be done, see posts:
    http://forums.augi.com/showthread.ph...ighlight=burst
    Make sure you code includes:
     (load "burst.lsp") ; doesn't autoload in lisp
    (sssetfirst nil SelectionSet) ; Sets which objects are selected and gripped
    (command "burst") ; bursts the SelectionSet
    If that doesn't do it post the code.
    Ph# (850)606-1516 Home Page
    2004-10
    Denver, Colorado
    1,515
    Quote Originally Posted by alanjt View Post
    Hmm. I see what looks pretty obvious as to what line needs to change to feed it my variable, but it's not working. Hard to trouble shoot without posting code... Where do you draw the line? Can I ask about a certain variable, maybe SS1, that seems like I could change to feed it my variable tmp? Just add tmp as a global variable?
    Phillip Bradshaw
    2008-02
    1,141
    The burst-one subroutine is the one that will need to be applied to all enames. So the subroutine will run successfully, grab all other subroutines except the main burst one.
    Dropbox
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,518
    You can post your code, but not code you have copied from the burst routine. That contains copyright protection.
  1. 2014: BURST command Error
    By darrellwinfrey589074 in forum AutoCAD General
    Last Post: 2014-03-25, 02:56 PM
  2. Looking to get the BURST command in LT
    By elipman in forum AutoCAD LT - General
    Last Post: 2011-11-14, 01:19 PM
  3. 2011: HIGHLIGHT reverts to 0 after burst command?
    By stimmo520 in forum AutoCAD General
    Last Post: 2011-05-09, 01:07 PM
  4. Using the Burst command with LISP ?
    By stephen.coff in forum AutoLISP
    Last Post: 2011-02-08, 04:20 PM
  5. Modified Burst Command
    By thomas-p in forum AutoLISP
    Last Post: 2006-03-17, 02:51 PM
