Results 1 to 8 of 8
Thread: Drawing a 3D curved line
    2012-12
    Brisbane Australia
    5
    Default Drawing a 3D curved line
    I need to draw a line that curves through all 3 Cartesian co-ordinate planes at the same time. ie. X,Y & Z planes. This is for a fan blade. My problem is, AutoCAD does not seem to allow this in any of its line drawing formats. 3D polylines can only be straight. 2D polylines can be curved but only in 2 planes. Can anyone help with this please?
    Earth
    9,805
    Default Re: Drawing a 3D curved line
    You can define a UCS from the 3 coordinates that make up the curve, then draw an arc.
    Will this work for you?
    See also: http://www.eng-tips.com/viewthread.cfm?qid=1217
    R.K. McSwain | CAD Panacea |
    2012-12
    Brisbane Australia
    5
    Thanks for the suggestion but no. The curve I need to draw does not look straight from any perspective you look at it. Sort of like a helix but without a constant radius (French curve type of thing). If you look at a domestic pedestal cooling fan blade, you will see what I mean.
    Member vmichl's Avatar
    2002-04
    C.Budejovice, Czechia
    34
    You can try SPLINE or approximated (calculated) 3D Polyline.
    Vladimir Michl, www.cadstudio.cz www.cadforum.cz
    2012-12
    Brisbane Australia
    5
    Thanks Vladamir. I will give it a try.
    2001-12
    St. Louis
    5,407
    Just curious if this worked for you?
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2012-12
    Brisbane Australia
    5
    Quote Originally Posted by Wanderer View Post
    Hi Wanderer,
    None of the above I am afraid. I have resolved the problem albeit in a long way around. I had to draw the curve in plan, then also in side elevation, extrude both as surfaces so they intersected each other then trace a 3d polyline onto the resulting intersecting line. I could then use the resulting curve as my sweep line. Seems to be the only way. Looks like a hole in AutoCADs modelling ability.
    Thanks for the enquiry
    Active Member ervin_david's Avatar
    2004-07
    Southeastern USA
    98
    You have to plot a series of points along the desired curve, then spline/knots/uniform, then select the points and enter upon completion.
  1. Drawing on a curved surface.
    By jjseeker in forum AutoCAD 3D (2007 and above)
    Last Post: 2013-07-11, 10:20 PM
  2. Drawing curved walls
    By fathibaali in forum ACA General
    Last Post: 2008-10-15, 05:46 PM
  3. how to make curved window with curved arch trim in curved wall
    By lcollot in forum Revit Architecture - Families
    Last Post: 2008-01-21, 02:46 PM
  4. Curved line based families
    By Archman in forum Revit Architecture - Wish List
    Last Post: 2007-07-03, 05:54 PM
  5. Straight Line from a Curved polyline
    By rhayes.99001 in forum ACA General
    Last Post: 2006-06-09, 09:25 AM
