Thread: Location of Call Out | Location of Detail
    2011-07
    5
    Default Location of Call Out | Location of Detail
    Happy Friday.
    I have searched for what i am looking for.. and i found this.. http://forums.augi.com/showthread.ph...=linking+sheet
    and it seems that help stopped... in 2009...
    I am working in Civil 3D 2011. I have our SSM set up with Model Views from a "source" drawing. Our blocks have 3 fields.
    Basically, Top half of the call out is linked to the view number.
    The bottom half is divided in 2.
    1. The left half is linked to the “Location of Call Out” or the plan view in our sheets.
    2. The right half is linked to the “Location of Detail” or the last few sheets where the details are.
    I’ll take you through the steps;
    I create a Model view in the plan view sheet. We’ll call it sheet C-03 and View1. I qsave and then open my detail sheet or sheet C-08. I will go to the “Model Views” tab, expand sheet C-03, right click on “View1” and “Place on sheet”
    The viewport is generated, the View Block is inserted. However, both fields of our block now say, “C-08 | C-08”
    Subsequently, when I go to the original plan view, sheet C-03, I now click on the “Sheet Views” tab, right click and select “Place Call Out” and our block. I insert the block on sheet C-03 and the fields populate correctly. “C-03 | C-08”
    I want to know how I can make the viewport block populate to be “C-03 | C-08”
    I have the view block defined as “SheetSetPlaceholder -> SheetNumber” for the left side. This is where I want the plan sheet number to be placed. I.E.: C-03.
    The right side is “CurrentSheetNumber” and displays correctly.
    Now in comparison, our callout block is defined like this:
    Left = CurrentSheetNumber
    Right = SheetSet -> “C-08” -> SheetNumber
    And it works.
    So, long story short.. How do I link a detail view to the plan view and the plan view to the detail view?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,099
    Default Re: Location of Call Out | Location of Detail
    I do not think this is available.
  1. Specifying 0,0 location
    By SimonBeau in forum Revit Architecture - General
    Last Post: 2012-07-25, 01:39 PM
  2. Define Detail location
    By duyen.nguyenthien in forum AutoCAD Fields
    Last Post: 2010-07-01, 05:55 AM
  3. CUI location(s)
    By sschwartz85916 in forum AutoCAD CUI Menus
    Last Post: 2006-04-04, 02:36 PM
  4. Detail origin and location with fields
    By jkipfer in forum AutoCAD Fields
    Last Post: 2005-08-25, 07:06 PM
