Results 1 to 10 of 11
Thread: Stupid Question - Piping system types: how to have return piping "stay" as return piping when drawing a bypass pipe?
    2007-10
    74
    Default Stupid Question - Piping system types: how to have return piping "stay" as return piping when drawing a bypass pipe?
    Stupid question: When drawing HW piping systems when you have a bypass between the HW supply piping and the HW return piping, how do you keep/lock the return piping system type as return?
    When the bypass is connected into the supply piping all the supply piping turns into return piping or vice-versa. How do we install a bypass pipe between the return and supply and keep / lock the supply pipe system type as supply and the return piping as systems type return?
    2005-11
    50
    Default Re: Stupid Question - Piping system types: how to have return piping "stay" as return piping when drawing a bypass pipe?
    I believe you need to add a coupling on the bypass line. This will allow for the pipe to be on two seperate systems.
    2007-10
    74
    Union's don't work for that. As I recovery from my brain-f%$t once you place a valve (duh...) you can assign one side as supply and the other as return. God I feel really stupid....
    I hate when REVIT makes a bumbling fool out of me. Guess REVIt is doing just what it should...
    2007-10
    74
    opps spoke too soon, this doesn't work.
    2011-08
    109
    I've just run across this scenario myself for when I tap outside air into a return air duct. And I have it on a DCW to DTW bypass below an instantaneous water heater. Would definitely like to know a proper method for this.
    2008-02
    Austin, TX
    210
    This is definitely a frustrating problem that needs to be addressed in the software as soon as possible. Our workaround so far has been to make a union-type connection family that is just a disc with a connector on either side, with the connector set to "other" so it can inherit any system type. It seems to work at this point, but Revit likes to make us eat our workarounds, so we'll see.
    2007-10
    74
    Ahh yes, I have run into this problem with ductwork too as described above by Thomas.
    Glad (?) to see I'm not the only one struggling with this one.
    2011-04
    8
    Any update on this issue ? Using a disc is a quite annoying workaround. When you add one on an existing pipe, it inherit the pipe's system type. If you change system type on one side the other side inherit this new sytem type…
    I don't know how it is in the US but here we almost always have a bypass or splitted loops (same water but different pump).
    2007-06
    Louisville, KY
    56
    wboyanton
    we use connectors primarily to separate sanitary waste for sanitary vent which in real life are physically connected. Similar I am sure to the disc mentioned. we put a put a system connector on each side of the extrusion. We also use ours as plumbing fixtures so we are not dependent on the architectural model for fixture identification and scheduling. I am sure that this process could be altered and the be mechanical equipment or any other entity that can host a connector. Hope that is clear as mud. I will gladly send you one of ours if you would like. I was going to attach one here but I don't see that option. So send me an email address if you are interested. sernspiker@luckett-farley.com
    2016-06
    Sydney, Australia
    Quote Originally Posted by AaronC View Post
    Has there been any development with this? Or is this still the best workaround?
    I am having the same issue with sanitary vents.
  1. 2015: Hydronic supply and Return Piping Visibility Issue
    By shmeds in forum Revit MEP - General
    Last Post: 2014-12-22, 10:47 PM
  2. Replies: 0
    Last Post: 2011-11-22, 01:49 PM
  3. show 4" or larger piping as a double line
    By davel.254027 in forum Revit MEP - General
    Last Post: 2011-09-09, 08:00 PM
  4. Single line 1/4"-2" piping
    By joseph_turc in forum Revit MEP - General
    Last Post: 2010-09-22, 05:29 PM
  5. "Create Return Air System" Icon Not Available
    By cporter.207875 in forum Revit MEP - General
    Last Post: 2009-12-02, 04:54 PM
