Results 1 to 8 of 8
Thread: Run Lisp Routine From Another Lisp Routine
    56
    Unhappy Run Lisp Routine From Another Lisp Routine
    In the attached lisp file I am trying to load and run the IB routine, but can't seem to get it to work.
    Any help would be appreciated.
    Thanks Mike
    2015-10
    Colorado Springs, CO
    369
    Default Re: Run Lisp Routine From Another Lisp Routine
    (DEFUN C:MONO33()
    (COMMAND "UNDO" "M" )
    (command "expert" "2")
    (command "psetupin" "c:/wilson/proto/newnewproto-mono.dwt" "*")
    (command "expert" "0")
    (COMMAND "PSLTSCALE" "1" )
    (COMMAND "LTSCALE" 0.33 )
    (COMMAND "IMAGEFRAME" "0" )
    (COMMAND "LAYER" "ON" "*" "")
    (COMMAND "LAYER" "S" "4" "OFF" "4,*|4,99,*|99,*MIKE*,98,*|98,*ATT*,*|*ATT*,1000,*|1000,VPORT" "Y" "")
    (command "tilemode" "0")
    ;(COMMAND "UCS" "W")
    (load "IB.lsp")
    (COMMAND "mspace")
    (COMMAND "c:IB")
    (COMMAND "pspace")
    (initdia)
    (command "_plot")
    ;(COMMAND "UNDO" "B" )
    I'm no expert... but just looking at this right quick I would say replace
    (COMMAND "c:IB")
    with
    (COMMAND "IB")
    I think I've only seen the c: during a defun statment. I.E (DEFUN C:MONO33()...
    The command that you run is then MONO33, not c:MONO33.
    Tallahassee, FL USA
    3,665
    Put the
     (load "IB.lsp")
    as early as you can in the routine, it may choke if it's to close to the function call especially if the file is big. If
     (defun c:IB ()
    is the function in the routine then the call is correct. If that doesn't do it you may need to attach IB.lsp as well.
    For setting system variables I'd use
    (setvar 'PSLTSCALE 1)
    rather than
    2008-02
    1,141
    Also, replace (COMMAND "c:IB") with (c:IB)
    Tallahassee, FL USA
    3,665
    Quote Originally Posted by alanjt View Post
    Opps! I've used the c: with functions calls many times, but missed it was in (COMMAND ""). On of those for the layer command should be enough.
    56
    Attached is the MONO33.lsp Revised, and the IB.lsp.
    What I am trying to do is push the image to the back, before plotting.
    Thanks Mike
    Tallahassee, FL USA
    3,665
    Try:
     (DEFUN C:MONO33(/ *ERROR* expert PSLTSCALE LTSCALE IMAGEFRAME tilemode)
      (load "IB.lsp")
     (defun *ERROR* (s)                    ; If an error (such as CTRL-C) occurs
                                          ; while this command is active...
      (if (/= s "Function cancelled")
        (princ (strcat "\nError: " s))
      (setvar 'expert expert)
      (setvar 'PSLTSCALE PSLTSCALE)
      (setvar 'LTSCALE LTSCALE)
      (setvar 'IMAGEFRAME IMAGEFRAME)
      (setvar 'tilemode tilemode)
      (vl-cmdf "undo" "Mark")
      (setvar 'expert 2)
      (setq expert (getvar 'expert)
          PSLTSCALE (getvar 'PSLTSCALE)
          LTSCALE (getvar 'LTSCALE)
          IMAGEFRAME (getvar 'IMAGEFRAME)
          tilemode (getvar 'tilemode)
      (setvar 'expert 1)
      (setvar 'PSLTSCALE 1 )
      (setvar 'LTSCALE 0.33)
      (setvar 'IMAGEFRAME 0)
    ;  (vl-cmdf "LAYER" "ON" "*" "S" "4" "OFF" "4,*|4,99,*|99,*MIKE*,98,*|98,*ATT*,*|*ATT*,1000,*|1000,VPORT" "Y" "")
      (vl-cmdf "LAYER" "ON" "*" "S" "4" "OFF" "4,*|4,99,*|99,*MIKE*,98,*|98,*ATT*,*|*ATT*,1000,*|1000,VPORT" "") ; removed "Y"
      (setvar 'tilemode 0); puts you on Model Tab
    ;(COMMAND "mspace")  ** Command not allowed in Model Tab **
      (c:IB)
      (vl-cmdf "pspace")
      (initdia)
      (vl-cmdf "_plot")
    IB.LSP looks ok.
    Last edited by Tom Beauford; 2013-07-25 at 03:11 PM. Reason: removed "Y" option from Layer command sequence
    56
    here is part of the dialogue,
    Warning: layer "TABTEXT" is frozen. Will not display until thawed.
    Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/PStyle/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: S
    Enter layer name to make current or <select object>: 4 Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/PStyle/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: OFF
    Enter name list of layer(s) to turn off or <select objects>: 4,*|4,99,*|99,*MIKE*,98,*|98,*ATT*,*|*ATT*,1000,*|1000,VPORT Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/PStyle/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: Y
    Invalid option keyword.
    Command: Unknown command "BACK". Press F1 for help.
    pspace
    Already in paper space.
    Command: _plot Regenerating layout.
    Regenerating model.
    it seem to not like the back command
  1. Calling up LISP routine from within another LISP
    By jimmy_goodall in forum AutoLISP
    Last Post: 2013-08-21, 05:56 AM
  2. NEED HELP WITH LISP ROUTINE - PURGE linetype lisp
    By ECASAOL350033 in forum AutoLISP
    Last Post: 2013-06-21, 01:13 AM
  3. Help with a lisp routine to add a 12" line to this routine
    By Orbytal.edge341183 in forum AutoLISP
    Last Post: 2012-11-14, 10:33 PM
  4. Combine three lisp routine into one routine.
    By BrianTFC in forum AutoLISP
    Last Post: 2012-02-08, 12:14 PM
  5. Replies: 9
    Last Post: 2012-01-21, 07:58 AM
