I used the Navisworks export tool in Revit to create a NWC file that I then included in the Navisworks file set that I am using. I thought that I would be able to select an item in the Navisworks file and be able to see the "Mark" for that item in the properties window, but I seem to have every property except the one that I want... "Mark". Any help would be appreciated.
Is the "Mark" field the accepted way to number equipment in Revit or should I be doing something different? Up to this point, I have been using the Mark field so that I can then "tag" my pipe accessories and mechanical equipment by utilizing this field.
