Thread: Print Preview Error
    2008-12
    New Jersey
    472
    Default Print Preview Error
    When I click on my Print Preview Icon on my Quick AccessToolbar I get the following error message:
    _previewThe selected layout has an invalid media configuration.
    It doesn’t happen for all of my drawings but does happen regularly. I can use the print preview fine using the plot command.
    Does anyone know what this error means?
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,686
    Default Re: Print Preview Error
    Using the plot command on an old drawing setup to plot to a plotter configuration we no longer have it alerts me that it automatically switched to the none plot configuration. If you use the print preview in the plot command and Apply to Layout before canceling does the Print Preview Icon work afterwards? It may not autocorrect like Plot does.
    2008-12
    New Jersey
    472
    Yes... That fixed the issue by applying to the layout.
    It would appear that no one has updated the standard template file that I use (probably cos I'm the only one who uses it) in a long time. I will update that and hopefully correct the issue with the template file as well.
    Thank you for the feedback and pointing me in the right direction to look.
  1. 2007: Print preview issue
    By Stagg99 in forum AutoCAD LT - General
    Last Post: 2013-03-27, 04:17 PM
  2. Print Preview problem
    By davykerr1 in forum Revit Architecture - General
    Last Post: 2009-12-15, 09:56 PM
  3. print preview
    By tect75 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2007-10-29, 09:26 PM
  4. Print Preview Thumbnail
    By Martin P in forum Revit Architecture - Wish List
    Last Post: 2006-06-15, 05:54 PM
  5. Fatal Error during print preview...
    By gseals in forum AutoCAD Plotting
    Last Post: 2004-09-24, 02:39 PM
